Air Con Trinary Switch
Old 07-25-2014, 04:24 AM
Gretsch's Avatar
Default Air Con Trinary Switch
I have a leak in the air con which is coming from the area in/around the Trinary Switch. I believe the part No is LNA 7657AB Aircon trinary switch.
Does anyone know where I could get one, or which other cars it was used on?
Does anyone have an 'old' one, I could use to determine exactly where the leak is
(UK Surrey area)
Old 07-25-2014, 05:24 AM
andersh's Avatar
Ask these guys, they're in Beare Green. Went there on Wednesday and they had 7 or 8 XJSs that they were breaking and sheds full of parts!
Simply Performance - 07796 002321
Gretsch (07-26-2014)
Old 07-25-2014, 05:55 AM
ptjs1's Avatar
Received 2,935 Likes on 1,956 Posts
Gtretsch,
LNA7657AB is still available from Jaguar, either online or through any Jaguar dealer. However, it was only fitted to x300 saloons, not XJS models. What car do you have?
Paul
Old 07-25-2014, 07:51 AM
rgp's Avatar
rgp
rgp is offline
Old 07-25-2014, 04:20 PM
Roger95's Avatar
I suggest that you use an interchange for it. It looks like the high side low pressure switch? As to your leak it may just be an o ring leaking.
Old 07-26-2014, 01:07 PM
Gretsch's Avatar
Thanks for the suggestions Roger95 .... but sorry I don't know what you mean by "interchange"
PS Totally impressed with the speed of replies and the willingness to help. Thanks.
Old 07-26-2014, 05:38 PM
ptjs1's Avatar
Gretsch,
I'm still not sure why you need LNA7657AB? It's not fitted on an XJS. Do you have an x300 saloon?
Paul
Old 07-27-2014, 09:40 AM
Roger95's Avatar
"Interchange" an alternate part who's form, fit and function are the same.
Did you take the P/N off the switch that's in your car? PTJS1 is correct in that the P/N you've provided is used in the X300. What model year is your XJS?
Old 07-27-2014, 11:42 AM
Gretsch's Avatar
Default Your right it's an LMB 7657AA
I took it off today and your right it's an LMB 7657AA !
Both top and bottom have ultra-violet dye showing (but there isn't a trail of dye from top to bottom)
I attach two pics.
The 1st showing that the 'top' (i.e. where the wires emerge) is not fitted fully. Is this 'cause the pressure has forced it out?? (surely not, but be pleased if someone would confirm)
The 2nd pic shows bottom and the 'O' ring - which (on re-fitting) isnt very compressible - so I definitely need a new one.
I'll try Simply Performance tomorrow to see if they have an LMB 7657AA.
Old 07-27-2014, 11:56 AM
ptjs1's Avatar
Gretsch,
Lmb7657aa is also still available new from any jaguar dealer £42 + vat. But it's fitted to XJ40s. We still don't know what car you've got? Can you just confirm that you don't have an XJS?
Paul
Old 07-27-2014, 03:41 PM
Gretsch's Avatar
Please be gentle with me .... it's a 1997 DB7 with 3.2 litre straight six,
and therefore lots of Jag parts.
Old 07-27-2014, 05:20 PM
ptjs1's Avatar
Gretsch,
That's fine, we're still happy to help! As I said, just go to any jaguar dealer and they'll have it in the next morning. Alternatively, order it from Jaguar online at Genuine Jaguar Parts and Jaguar Accessories for Classic Jaguars from Jaguar Classic Parts UK
Good luck
Paul
Old 07-28-2014, 04:25 AM
Gretsch's Avatar
I've ordered one, and hopefully it comes with the 'o' ring.
I'll update in a couple of weeks as to whether it has cured the leak.
Thanks all for your help.
tonyforman
09-10-2015 07:23 PM
1964Daimler
09-09-2015 11:28 AM
1100me
09-07-2015 06:26 AM
Corycarlo
09-05-2015 11:41 AM
laserguy
09-03-2015 02:02 PM
Quick Reply: Air Con Trinary Switch
