The Blue Goose: Adventures of a first time Jag owner
#141
HA,
ECU is the fueling control mystery unit tucked up inside the RH buttross.
The 6 and 16, NO idea. The 6 was the original unit and did its task well within the limitations of the technology of the time. Somewhere around late '86 came the 16 unit, with vastly improved lectrickery bits and data processing, and much improved reliability.
Worry not about it, it needs no looking after.
orangeblossom (08-27-2014),
paulyling (08-23-2014)
#142
Received 6,317 Likes
,chirped in the dry quite a few times. But usually when taking off from stand still on a left turn at an intersection.
The following 2 users liked this post by o1xjr:
#143
no worries. Cool so the Blue Goose's ECU is better than the original spec. Groovy. Im gonna give her an extra pat in the morning.
Best I dont know where it is so the temptation isnt there to tinker. Electronics is up my alley ha ha ha.
Ha ha, i gotta treat those Pirelli's nice...for a while. If my Mrs found out how much each tyre cost me she might come at me with the Butchers knife!
Next expense....the radio. I cant truly experience the ride until my music is in order. Local radio sucks.
But speaking of listening. Man I love the sound of that V12. It makes a kinda quiet windy sound ( dont know how to explain it) when i put down the throttle and you can just feel that power. Its freakin awesome yet bizzare at the same time. I get hoons in my street that feel their engines have to be as loud as possible so I know whey are running up my street, but i dunno, the Goose just does it with extreme elegance.
It doesnt need to be loud.
#144
well i went out and got my blanking cap today. Gonna wait until the Goose cools down and pop er on. Then will monitor fluids.
Also picked up a new head unit today which I am gonna install tonight:
https://www.jaguarforums.com/forum/x...-87190/page11/
Also, since getting the Goose i have taken over the garage which was once a TV room for the kids. I have found a comprimise. It is called "Drive in Movies"
The following 2 users liked this post by Mkii250:
paulyling (08-25-2014)
#146
#147
Took Wifey for her first ever cruise today. I think she secretly liked it. She's not a real fan of cars.
It helped that I was bumpin the 80s so she was singin along whilst we cruised the beach front. I also wanted to show er what the Goose could do on the Freeway but there was bloody road works crampin my style!
#148
Paulyling, if you like the sound of the V-12 now, add some "growler" air cleaners and R-E-A-L-L-Y enjoy the sound! Also flipping the trans kickdown switch to the top of the plate will give you kickdown at 3/4 throttle vice WOT for more spirited driving.
If you look at the top left of the picture you will see the kickdown switch placed on top of the plate so that the throttle arm contacts it at 3/4 throttle, also look just below and you'll see the en-richer switch next to the capstan, this must "make" just before the kickdown to enrich the mixture at the nozzles just before kickdown.
The following 2 users liked this post by JTsmks:
paulyling (08-27-2014)
#149
Does this have any detriment on the engine?
And what were the type of air filters you were referring too? Does the filter media allow a different sound as the air passes through? Sounds really cool
Look forward to hearing back from ya mate.
Also, thought I might post some interior pics of the Goose. Shes in pretty good shape save for a few things to be expected from a 29 year old car.
With cracked wood grain, Im guessing you'd have to tear it out and replace right? No other solution?
Any hints on cleaning the inside of yours and keeping her lookin chipper?
The following 3 users liked this post by paulyling:
#150
No, the one next to the potentiometer (capstan) is the en-richer (hit it at idle and she'll "pick up" as the ECU sends "more fuel" signal to the injectors. The one I mean is right where the throttle cable is mounted just before the cable enters the capstan there is a plate and under that plate is a micro switch that provides "kick down" ie "passing gear" that will only "click" with your foot planted firmly through the floor. Pulling it off and flipping it to the top of the plate allows the throttle arm to contact it at 3/4 throttle vice full foot through the floor.
#151
Damn JT that sounds awesome! Now bare with me, remembering I am but a beginner, do you mean the little microswitch that sits there on the throttle disk? Once you reach a certain point on the throttle, the disk hits the little microswitch, and drops her down to 2nd gear right? So you mean to move this switch so as the gear change happens sooner? (Forgive me for my ignorance). Im I in the ball park? Does this have any detriment on the engine? And what were the type of air filters you were referring too? Does the filter media allow a different sound as the air passes through? Sounds really cool Look forward to hearing back from ya mate. Also, thought I might post some interior pics of the Goose. Shes in pretty good shape save for a few things to be expected from a 29 year old car. With cracked wood grain, Im guessing you'd have to tear it out and replace right? No other solution? Any hints on cleaning the inside of yours and keeping her lookin chipper?
http://www.v12performance.com/kit.html
#152
So....i took a look under my bonnet. Now are you referring to the rotating part that is pulled by your throttle cable, as the Capstan?
Under mine there is only one micro switch. By operating it by my hand it looks like when the pedal is pushed to the floor, the cable pulls the rotating disk around which eventually makes contact with the micro switch at about 180 degrees turn from the original position. With this contact closure, does this not send the signal to change gears? (red circle)
It appears there also used to be a micro switch fitted where i have put the green circle, near the throttle cable. Maybe this is the cause of my confusion as I dont have the same set up as yours.
I thought maybe it is because my XJS is the year earlier (1985) however it appears there used to be something there as there is a mark left behind.
I also checked out the air intake pack you linked me. I understand it alot better now.
Thanks for all the info. Im learning everyday.
Well, tomorrow im gonna take the Goose for a country driving. Lots of hills and beautiful scenery to behold up in the Maleny, Montville area.
Question. I have a very steep hill to traverse down on the way home. Would you guys recommend i drop the Goose down to the 2nd gear whilst i climb down the hill? Well this help to go easy on the brakes?
Clarke how do you go with Fireball down that big bloody hill from Maleny down to Landsbrough?
later guys
#153
Gday JT thanks the reply. Im lovin this as a learning experience, because as you know, Im pretty green with it all. So....i took a look under my bonnet. Now are you referring to the rotating part that is pulled by your throttle cable, as the Capstan? Under mine there is only one micro switch. By operating it by my hand it looks like when the pedal is pushed to the floor, the cable pulls the rotating disk around which eventually makes contact with the micro switch at about 180 degrees turn from the original position. With this contact closure, does this not send the signal to change gears? (red circle) It appears there also used to be a micro switch fitted where i have put the green circle, near the throttle cable. Maybe this is the cause of my confusion as I dont have the same set up as yours. I thought maybe it is because my XJS is the year earlier (1985) however it appears there used to be something there as there is a mark left behind. I also checked out the air intake pack you linked me. I understand it alot better now. Thanks for all the info. Im learning everyday. Well, tomorrow im gonna take the Goose for a country driving. Lots of hills and beautiful scenery to behold up in the Maleny, Montville area. Question. I have a very steep hill to traverse down on the way home. Would you guys recommend i drop the Goose down to the 2nd gear whilst i climb down the hill? Well this help to go easy on the brakes? Clarke how do you go with Fireball down that big bloody hill from Maleny down to Landsbrough? later guys
#154
The switch in the green circle is the kick down and gets moved to the top and the one in the red circle is the en-richer and should be engaged just before the kick down makes. Putting the switch in the green circle to the top allows the throttle arm to hit the switch vice the cable and allows the kick down to engage at a more appropriate time for more "spirited" driving vice only coming in at WOT.
#155
Cheers bud. This is why i love this forum. In just a few threads you have me googling what is WOT ( no pun intended) and kickdown ( i told you im green ) but nah this is great. Your information has me searching for more information.
To be honest, as interested i am on the subject, ill leave the Goose her quiet ellegance for now, but JT i really appreciate the info mate. Sounds like your switched on. Another question for you though:
* You have a loud and roaring V8 going up and down the street. You can hear it a mile a way. Everybody knows its coming.
* You have a quiet and ellegant v12.
What would make the V8 have more grunt and power (ie able to go faster quicker) when compared to a V12? I understand this mighten be a simple answer but just curious. I mean the V8 obviously SOUNDS alot more powerful, but would this necessarily be the case?
Also, I understand Jag had some success with the XJS back in the late 80s on the racing circuit but kinda dropped off after that. Were they racing other V12's back then?
Anyways, i appreciate the discussion. Might post some pics tomorrow of my cruise. Gotta take the lady out tomorrow so hoping the Goose behaves
#156
Cheers bud. This is why i love this forum. In just a few threads you have me googling what is WOT ( no pun intended) and kickdown ( i told you im green ) but nah this is great. Your information has me searching for more information. To be honest, as interested i am on the subject, ill leave the Goose her quiet ellegance for now, but JT i really appreciate the info mate. Sounds like your switched on. Another question for you though: * You have a loud and roaring V8 going up and down the street. You can hear it a mile a way. Everybody knows its coming. * You have a quiet and ellegant v12. What would make the V8 have more grunt and power (ie able to go faster quicker) when compared to a V12? I understand this mighten be a simple answer but just curious. I mean the V8 obviously SOUNDS alot more powerful, but would this necessarily be the case? Also, I understand Jag had some success with the XJS back in the late 80s on the racing circuit but kinda dropped off after that. Were they racing other V12's back then? Anyways, i appreciate the discussion. Might post some pics tomorrow of my cruise. Gotta take the lady out tomorrow so hoping the Goose behaves
paulyling (08-28-2014)
#158
Not to dispute Flints personal observations on the XJS being a "knicker peeler" I find it interesting that my 97, XJ6L in Titanium Pearl seems to have a far greater effect on the opposite sex then my Black, XJS. I get tons of complements from guys (I know, weird huh) on the XJS but constant attention and compliments from woman when out and about on the X300. No matter how you slice it in the automobile world a Jaguar gets the "Job Done" in a way no other make can, from coupes to convertibles to saloons! Side note, my friends 91, XJS coupe in oyster with wires and three eared knock-offs REALLY seems to be the best "lure" by far!
Flint Ironstag (08-28-2014),
#160
I have a very steep hill to traverse down on the way home. Would you guys recommend i drop the Goose down to the 2nd gear whilst i climb down the hill? Well this help to go easy on the brakes?[/B]
later guys
later guys
paulyling (08-29-2014)
