center dash vent modification
as we all know, the XJS has a bit of an asthmatic ventilation system , and this isn't helped by the huge vent in the middle of the dash ,
831 by MyPix on Talk Photography
it has been a known upgrade to fit the later facelift vent and or a modified one from a 40 or something, the facelift vent if you can get one is £100 or more though , so not a lot bother with carrying out this minor work
I had a slightly different idea ,
why not blank off the middle fixed section and force what little air there is to the two adjustable side vents of the outlet
with this in mind I purchased a good used centre vent for the XJS , and proceeded to chop it up :shock:
but I did have a plan , I bent some sheet tin , and formed a ' pocket ' and then covered it in period looking flock that has an adhesive backing , and ended up with this
824 by MyPix on Talk Photography
not bad if I say so myself
I then went to my car and removed my perfectly sound original vent, this is easily done by dropping the glove box door and gently prying off the walnut trim with a suitable tool , and
then removed the vent which is just a push fit
832 by MyPix on Talk Photography
and then installed my modified vent grille , and put the walnut trim back in place
833 by MyPix on Talk Photography
I still have my original vent should I wish to go back , but now have somewhere other than the ski slope to put change or keys etc , slightly too small for my iPhone though :roll:
and as for the extra air ?? , well , its a little better , lmfao :mrgreen:
BB
BB
The following 3 users liked this post by Brake buster:
The following 2 users liked this post by Brake buster:
Flint Ironstag (01-27-2015),
Japthug (01-28-2015)
the gear shifter knob is a Jaguarsport upgrade ( XJR-s or TWR ) , and can only be fitted to a threaded shifter stick
your shifter has the ' t-bar ' shifter by the sounds of it , this can be cut and threaded, or a genuine Jaguar replacement fitted.....
thread size on mine is 8mm
BB
FS[Western US]: Jaguar X308 MISC Parts
perezal
12-29-2015 08:48 PM
PinnacleWax
Detailing / Car care
09-16-2015 10:28 AM
1964Daimler
09-09-2015 11:28 AM
