Cruise control, 1996 4.0 2+2
I badly need to fix the cruise control on this car. It runs so easily at highway speed I have to constantly raise my foot off the gas pedal. I got a speeding ticket Sunday for 67 in a 55 zone. First speeding ticket in 37 years.
I remember that aftermarket cruise controls could be gotten but now I don't see them.
600 mile trip this last weekend with no problems and no oil usage. Pleased, to say the least.
Thank you for any thoughts, RagJag
RagJag (09-30-2013)
+1, very common problem. Also make sure that the vacuum hose is connected securely to the bellows and the pump.
If good there, check the the connectors on the pump and dump valve.
Then I would check the cruise control module which is under the cover in front of the passenger seat. make sure all the connections are clean and tight, including the ground.
Check that you have 12v on pin 1 when ignition is on.
Check resistance on pin 17, it should be open circuit when the CC switch is off, 100 ohms when 'set' is pressed and 300 ohms when 'resume' is pressed. If not then pull the switch from the center console and check it.
You can download the electrical guide from the 'How to" section at the top of this forum.
Cheers,
Allan
Cheers,
Allan
The following 4 users liked this post by AllanG:
https://www.jaguarforums.com/forum/x...celift-101308/
Allan,
He has a 96 like mine. The cruise control module may be over the rear driver's side wheel well.
I know its strange, and my service manual doesn't acknowledge that location, but that's where his may be as well. It'll definitely be easier for him to get to!
Allan,
AllanG (09-27-2013)
Thanks for putting me straight Vee
Cheers,
Allan
My cruise control module failed. It is on passengers side foot well under the carpet and cover plate in front of the seat. Foot well had filled with water at some time. $20 on eBay. This was after confirming that sucking on the bellows worked and that the vacuum pump created a vacuum and tat the vacuum dump valve did not have a leak. Dump valve and pump are tough to get to and sort of behind the overflow tank on front left engine bay.
Softball60 (09-05-2020)
So I just found out that my cruise control isn't working!
I do have 12V on Pin 1, and I can get to 500 ohms when pressing resume. I also get to 108 ohms when pressing set, however I don't get anything when selecting the cruise switch to on. (I was getting 50 ohms initially, but I don't get it anymore)
Seems like the switch, no?
Well, Vee the cruise control has too many things that will keep it from working if any of them are not right. Module, gear shift switch, transmission module, console switch, resume switch, vacuum pump, and actuator bellows are most of them.
In testing yesterday, pin #1 had 12V if ignition is on. Pin 17 had 100 ohms resistance when 'set' but I got nothing on the resume button. I don't have any step by step instruction on this thing.
RagJag
RagJag
I don't know that you would see a particular resistance on pin 17 when the switch is in the ON position?
Check output voltages on Pin 10 and pin 3 of the CCM when the switch is set to ON the signal goes to ground on pin 10 and 12v on pin 3, when off it goes the opposite. If it does your switch should be good.
Cheers,
Allan
OK,
I got the vacuum pump to make a click sound when I fed it 12v of power.
I could not get the dump valve to make any sound with 12v of power.
I'm going to assume it's the dump valve. I took it off, cleaned whatever I could clean and put it back on with no change in results.
If anyone knows how to diagnose a the dump valve, I'd appreciate it. It seems like it would be easiest to find the problem if I could check things while the car was moving above 30MPH, or whatever speed needed to activate the cruise control.
Thanks for the continued help.
The valve should be getting 12v when the system is inactive, check the PM5 connector at the valve to make sure it's there and the connection to ground is good. The wiring diagram shows states that the valve closes when approx 0.5v is applied. So if you have a variable power supply, apply 0.5v to the valve and then using a hand vacuum pump apply vacuum to the valve. The vacuum should hold steady. If you switch the input to 12v the valve should release the vacuum.
If that works, you said that you heard the vacuum pump make a noise when you applied power, did you check to see if it is actually generating vacuum? Stick a gauge on it to check.
Cheers,
Allan
Cheers,
Allan
Cheers,
Allan
RagJag (10-26-2013)
Yes, there are a couple of models. Some use ODB speed input and some use separate VSS input, there are also models for electronic and mechanical throttle. This one has its own VSS input and is for mechanical throttle.
Here is the one I am looking at
Rostra 250 1223 Universal Cruise Control KIT W 250 3743 Right Side Handle Stalk | eBay
Rostra 250-1223 Universal Cruise Control System
