In Dash Computer
Old 12-18-2014, 09:10 PM
jomo's Avatar
Default In Dash Computer
Hi,
I have a 95 xjs convertible 2+2(actually 94.75). Are all convertibles 2+2?
On my dash I have a clock and was wondering if I replaced the clock with the in dash computer along with the corresponding wood trim will the computer work?That is do I have the necessary module in my trunk/boot?
Jomo
Old 12-19-2014, 03:23 AM
ptjs1's Avatar
Received 2,935 Likes on 1,956 Posts
Jomo,
Unless there's something bizarre about US cars, the answer is absolutely Yes. I've done it to a 95 & 96 car. Just plug it in and everything works straight away.
Paul
jomo (12-19-2014)
Old 12-19-2014, 07:30 AM
petemohr's Avatar
Originally Posted by jomo
Hi,
Jomo
I'm confused. What "in dash computer"?
Old 12-19-2014, 09:28 AM
Sarc's Avatar
This thing......
As well as being a clock and trip computer, it also gives you the FF fault codes that accompany the check engine light. Quite useful. As others have said, the wiring is all there.... just get a trip computer (and the panel surround), unclip the 4 switches at the sides and add into the new panel, and you are good to go
The panel you see in my car came from Pauls Jag off ebay..... he has some more left...... http://www.ebay.com/itm/NEW-Gorgeous...-/111542697254
Old 12-19-2014, 10:00 AM
Vee's Avatar
Vee
Vee is offline
Received 1,508 Likes on 1,175 Posts
Definitely plug and play.
Definitely no FF codes on the 95 and 96 models. We have an OBD2 port for that.
Panels for the trip computer are still available new from JDHT, by the way.
Old 12-19-2014, 10:30 AM
Bc xj's Avatar
I have a couple computers I will sell if you need.
1 from a 86. 1 from a 89.
Old 12-19-2014, 11:21 AM
Greg in France's Avatar
Received 9,079 Likes on 5,347 Posts
I do not think they will work in a facelift car.
Greg
Old 12-19-2014, 11:29 AM
jomo's Avatar
Originally Posted by ptjs1
Jomo,
Paul
Any year will work? Model dac 4296? The fault codes will also work with these computers on my car?
Thanks so much,
Jomo
Old 12-19-2014, 11:31 AM
Vee's Avatar
Vee
Vee is offline
DAC7362 is the one you need for an US spec XJS 95-96.
The older models will not work.
jomo (12-19-2014)
Old 12-19-2014, 11:34 AM
jomo's Avatar
How much with shipping to the US. Please understand that they are on sale at ebay for $45 but I would prefer making the purchase from a forum member.
Jaguar XJ6 XJS Trip Computer | eBay
Thanks,
Jomo
Old 12-19-2014, 11:37 AM
jomo's Avatar
Thanks Vee. That is what I needed to hear. What years is that model from?
Thanks,
Jomo
Old 12-19-2014, 12:42 PM
Vee's Avatar
Vee
Vee is offline
I believe all facelifts? 93-96.
Works on the v12 as well as the I6.
jomo (12-19-2014)
Old 12-19-2014, 05:02 PM
ptjs1's Avatar
Facelift cars all have the same later trip computer. I very much doubt that you'll find a facelift computer for $45! If you can find them working at that price, buy every one you can find! In the UK, a facelift computer is usually over £125.
Facelift cars are all XJSs built after March 1991. Any car that has a VIN higher than 179737 is a facelift car.
Paul
Old 12-19-2014, 05:12 PM
jomo's Avatar
Paul
Paul,
The ones I saw for $45 were pre facelift cars. The newer ones are much more than that! I was not aware that there were two types. Thanks for the reply.
Jomo
Old 12-19-2014, 07:16 PM
Vee's Avatar
Vee
Vee is offline
Be prepared to spend about $200
Old 12-20-2014, 12:13 AM
Bc xj's Avatar
If anyone needs pre facelift computer I will sell for $45 plus shipping
Old 12-20-2014, 02:47 AM
malc4d's Avatar
The US cars computer reads in US MPG, DAC7362. The others read in UK MPG, DAC7361. The Lt per 100 KM reads the same
Old 12-20-2014, 05:06 AM
ptjs1's Avatar
malc4d,
Good point. There is a different part number for UK computers (and a different one for Japan).
I guess the fuel flow sensor just sends flow signals and it is the trip computer that determines a value of actual fuel used. So it is the US computer that is necessary for US gallon calculation compared to our ones which do imperial gallon calculation.
So a non-US computer would probably work but you'd get Imperial Gallon consumption figures (which would make you feel better!)
Paul
mat32essex
10-03-2015 04:12 PM
Fletch44
09-28-2015 02:21 PM
Long Islander
09-27-2015 03:45 PM
the guardian
09-25-2015 03:06 PM
Quick Reply: In Dash Computer
