facelift 4.0 backdate?
I'm going to say that it should be a direct fit, but it would certainly help to know how far back it came from. If you posted a pic, that would be great too.
You will probably need to construct harness for the two lights. I believe the plug you have for your current headlight only lights up one bulb, now you'll have two and I don't believe you'll be able to use the old wiring.
You can tap into the wires. Black is ground. Blue/white is high beam, Blue/Red is low beam and I can't remember what the daytime driving, or city light wire is attached to. But that's going to be the challenge in making this work.
mine are patina’d and have been buffed out already so I assume that the light yellowing is internal. Otherwise fully functional and water tight. Im sure you could make better use of them since I doubt my car will ever be at a collectors knitpick fest. Plus Ill be able to recoup any money spent on replacement lights. Lemme know
chXFS
05-30-2022 11:02 PM
CruizinKev
10-09-2017 09:12 AM
