Door locks not operating
Old 08-24-2014, 01:54 AM
K10MRG's Avatar
Default Door locks not operating
Hi
After standing for a period of time my battery went flat. I attempted to open the doors of my 1992 XJS, but the doors will not open. I have charged the battery but the doors will still not open. Can anyone advise me how I may gain entry to my car.
Thank you
Old 08-24-2014, 03:41 AM
Jag93's Avatar
Use your key. Sometimes my power locks will open and shut in one second. It is some type of quirk. If it happens, I just use the key to open it up.
Old 08-25-2014, 03:07 AM
K10MRG's Avatar
Hi, I have tried the keys and still not opening?
Old 08-25-2014, 08:53 AM
MHF25's Avatar
I own a 93 XJS. Experiencing the same issues with the locking and unlocking the doors. I also replaced the old battery with a new and better one. Doors worked fine for one day. Then it reverted back to not being able to manually open or power open. I had to put a shim down the side of the door glass to work the chrome door lock knob loose. Once I had the doors open, I lowered the glass just enough to gain access IF and WHEN this happens again. I have no clue as to how to fix this mess. Basically, I cannot lock the car with the windows fully shut.
Old 08-26-2014, 02:51 PM
K10MRG's Avatar
Thank you for responding. I will have to revert to an unconventional way of gaining access to my car.
It would be good if someone has experienced this problem and have resolved it.
Old 08-26-2014, 03:47 PM
ptjs1's Avatar
Received 2,935 Likes on 1,956 Posts
Lots of owners have had similar symptoms. When you turn the key, what happens to the chrome internal lever? Does it move to the open position but the lock not disengage, or does it not move?
It's usually one of two problems - the door lock actuators (you might have solenoids on a 92 rather than the actuator microswitch) or the adjustment of the remote bars from the chrome lever.
You haven't said if you've got a Coupe or convertible. Entry is obviously easier if you have a convertible. However, at least with a facelift XJS, it can be easier to get past the drivers window with something to actuate the chrome remote lever.
Good luck
Paul
Old 08-28-2014, 04:41 PM
K10MRG's Avatar
Hello paul
The chrome lever does not move, so it looks like I will have to gain entry in an unorthodox way and have a look to see if the remote bars require adjustment or replacement solenoids are required. The car is a coupe.
Thank you
Robert
Old 08-28-2014, 04:58 PM
Vee's Avatar
Vee
Vee is offline
Received 1,510 Likes on 1,176 Posts
Did the keys ever operate the door lock?
Old 08-28-2014, 06:23 PM
ptjs1's Avatar
Robert,
Just a thought:
- Check the voltage of the battery in your remote and change if necessary.
- Disconnect the car battery for 30 minutes
- Connect the car battery
- Get close to the car and point the remote at the right hand part of the body, just behind the door and just above the sill and activate the remote.
That's the best chance you've got of the remote working.
When you operate the door locks with key, what happens? Does the key turn satisfactorily? Can you hear a click from the door? Does the chrome lever open then immediately close? What happens on the passenger door? Does the boot lock unlock when you turn the key?
Paul
Old 08-29-2014, 04:15 AM
malc4d's Avatar
Does the car have a Jag alarm / remote key fob ?
Old 08-30-2014, 04:26 PM
K10MRG's Avatar
Yes. The keys did work
Old 08-30-2014, 04:33 PM
K10MRG's Avatar
When the key is operated, there is no clicking noise on either side. The key turns with no difficulty. The boot can still be locked and unlocked with the key.
Old 09-01-2014, 12:34 PM
Vee's Avatar
Vee
Vee is offline
This is going to be difficult since apparently both locks are broken. I have an issue where only the passengers side lock won't work. Same problem as yours, the key turns effortlessly, but without purpose.
I removed the door cards from both doors and compared the two. It took awhile, but I realized that I was missing parts BEC8982 and BEC12378
You probably have a missing part or two that has broken off.
I recommend that you go to the JDHT website, open up their door lock scheme and start figuring out what's there and what isn't. It would be much easier if you had a better control to work from, but I'm afraid that's the best it's going to get!
99xk8guy
06-05-2023 06:28 AM
kevinl
10-31-2019 06:15 PM
dsnyder586
04-04-2019 02:38 PM
XJsc-guy
11-23-2015 01:56 PM
jagent
09-12-2015 09:10 AM
Quick Reply: Door locks not operating
