FI Harness update
Old 07-16-2014, 02:43 PM
Terry's Avatar
Default FI Harness update
It's built and installed!
Building a new harness isn't difficult, just a little tedious, but, worthwhile and satisfying. It looks daunting, but take notes and pictures and you can't really screw it up.
I bought all the parts from Del City and I am very pleased with the service I received from them. I highly recommend them. I routed the harness from the rear as has been suggested. Made things a little neater looking. For a connector I used a 5 way trailer light connector from NAPA, about $6. The connector is sturdy, weather tight, and about 2" long x 1" wide x 3/4" thick. Very compact and made of hard rubber, it also comes in a 6 way of the same size. Just by coincidence the wire colors matched the colors I used on the harness. Go figure! $130 total.
While I was at it I removed the fuel rail and injectors. I sent the injectors to Jaguar Fuel Injector Service and had them tested, cleaned and serviced as needed. Service was excellent and a week and a half turn around California to Florida. I highly recommend them also. $305.50 total
I also replaced all of the fuel lines under the hood, changed the air filters and changed the oil and filter.
I turned the key yesterday afternoon and voila, it fired up and runs smooth. All things considered it was an enjoyable and rewarding project.
I especially enjoyed building the harness. How many Jag projects can be done sitting comfortably at the kitchen counter with a cocktail, or wine or beer if you prefer, within reach!! Damn, I may go into business.
Now I have to address a trans fluid leak that appeared just before I put the car in the garage for the FI redo. The leak appears to be between the trans and engine area. I didn't notice anything obvious and really couldn't tell whether it's migrating or just dripping straight down. Bummer, no more bar stool, back to the concrete floor!!
The following 2 users liked this post by Terry:
86jag (07-19-2014), Gunner01 (07-21-2014)
Old 07-19-2014, 07:37 PM
86jag's Avatar
Can you post some pictures of your harness and a parts list from Del City? I am just about to do this in the next few weeks. I looked up the Del City website, how did you get your wire in less than 100ft rolls?
Thanks!
-Scott
Old 07-19-2014, 08:39 PM
superchargedtr6's Avatar
I built my new Marelli harness myself, from the Marelli ECU out. I did mine on the car. The harness that was on the car had a great amount of extra wire, and duplicate wiring that served no purpose at all. A little time, a little wine, and as you say, it turned out great. A very rewarding project.
Old 07-21-2014, 09:45 AM
Terry's Avatar
Thanks!
-Scott
Scott,
I can't send a pic of the harness as it is already installed. The original harness is like supercharged said, it has way more wire than necessary and is overly complicated. I ended up using 6 wires and 5 colors and putting it all in 3/8" loom.
My Del City parts list consisted of:
16 injector solenoid connectors #73522 $1.31 ea. ( i always buy a spare or two)
100' of hi temp split loom #774 $18.92 I'm not sure the high temp is necessary, this is 100' minimum, you can get split loom at Fryes, O'Reillys etc.
100' each of 16ga. GXL cross link wire at $11.78 a spool. 100' is minimum order.
Blue 4116103
Yellow 4116106
Green 4116104
Black 4116105
Red 4116101
White 4116102
Brown 4116107
I ordered all 7 colors just because that's how many they had and it doesn't hurt to have extra wire around.
I also used the 5 way trailer light plug from NAPA, very compact, sturdy and weather proof.
I don't know how to post pics but if you pm me I can text a pic of the scheme I drew up for the new harness.
Terry
The following 3 users liked this post by Terry:
86jag (07-21-2014), Gunner01 (07-21-2014), macudc (07-21-2014)
Old 07-21-2014, 08:44 PM
The Marelli harness had several circuits doubled back to points that could have stopped far earlier. My car is a late 89, which only had coax going to the engine speed sensors. I opted for the later style, where coax went to the amps too. My harness is FAR smaller, less complicated. I just used the wiring diagram, started one circuit at a time, to its point of destination, and kept at it. At first, its overwhelming, but once you do a few wires, even having to unsolder, resolder a new way due to something you figured out along the way, it gets less and less daunting. I used a cheap soldering iron, and lots of patience. Had never done it before, and it worked out great.
Old 07-21-2014, 08:50 PM
It hasn't been mentioned yet, but I bought heat shrink from my local Pep Boys in a kit of several various sizes, and a cheap heat gun. I had to undo a couple of my connections, would up buying another kit because I ran out/low on two of the sizes, but it really does look great if I say so myself. I could take pics if you wanted them, but I doubt very seriously you could tell anything from the pics unless you had very good shots of a original harness bay to compare it to.
Old 07-24-2014, 10:13 PM
86jag's Avatar
Terry just sent me the pics of his fuel injection harness and a wiring diagram. Many Thanks!!
Old 07-27-2014, 09:00 PM
macudc's Avatar
How does the harness for a 96 6L v12 differ? On my harness the wires for the 2 ignition coils run into the wiring loom. Can anyone point me to a schematic or diagram for the right loom?
Old 07-28-2014, 07:03 PM
86jag's Avatar
Starting in late 1990, Jag changed the connector types to a more modern style and put the ignition harness and fuel injection harness as one assembly.
I have found this website Jaguar Wiring Harnesses By Macharness
You can see how many more wires are in this harness. I would recommend rebuilding the FI harness and then soldering them into the rest of the harness. Assuming the rest of the harness is in good shape.
Newark Nj Gang
10-02-2015 02:39 PM
JagBrian
10-01-2015 12:52 AM
aadjei
09-25-2015 03:07 PM
Quick Reply: FI Harness update
