fuel tank
It can be replaced with a different design, but having the same function; but what is the point?
Greg
thanks for reply.
ok then ill keep it it makes sense to me know as to what its purpose is thanks..one more thing.i noticed a vacum line with what looks like a small plastic black filter of some kind in line.comming out under batter by small gas tank its not hooked up any ideas what and where it goes.thanks
Received 10,746 Likes
Hmmmm.
Sounds like the vacuum hose that goes to the ECU. It has a black filter cannister.
The ECU is behind a panel near the RH trunk lid hinge, roughly speaking. If it doesn't have a vacuum hose attached, there's your answer!
How is the engine running? It'll run poorly if the ECU vacuum hose is off!
jagernut (06-20-2014)
84 jag xjs ecu
I bought the car not running.it turns over.car sat for 3 or 4 years so i drained fuel tank and cleaned small tank out bought new fuel pump.and fuel filter.chaned oil and filter.and new battery.i got car from orig owner.all electrical works.i want to get it running i hope.i see ecu in trunk hooked up.also another one loose in trunk. ill check the one alteady hooked up and see whats up with vacum hose not attached.thanks for info.
hen555
09-07-2015 11:13 PM
deanh
09-06-2015 08:20 PM
