has any one put 17x8 with 255/45ZR17 98W BSW on their XJS
and both are the same rim coventry hornet
High offset
17x8 +42 offset
ronbros (12-02-2014)
The inside of the tire might rub inner side of the fender wall, but can be avoided with a 5mm spacer or something.
The following 2 users liked this post by Japthug:
Jonathan-W (12-02-2014),
8.5" with 42 should JUST fit but might be close.
Wheels can be modified, center bores reamed and PCD changed from 5x120 to 5x120.65. In some places like Australia spacers are illegal so have the wheel modified with an insert bolted to back of the wheel to change offset.
Any non XJS wheel will require some modification. Even if it is only spacers. XJ40/X300 wheels fit with spacers for the front.
ronbros (12-11-2014)
Received 1,231 Likes
my tires are 275-35-18 frt,, 295-35-18 rears, and dont rub lock to lock!
been 20 yrs ,Maybe i was ahead of the curve back then, should i go to smaller tires?
this whole thing about tires and wheels is just a personal thing, and something to talk about.
to each his own, really all they have to do is go down the road, and make the owner happy!
and do you have pictures?
deanh
09-06-2015 08:20 PM
