has any one put 17x8 with 255/45ZR17 98W BSW on their XJS
Old 11-30-2014, 09:28 PM
Jonathan-W's Avatar
Default has any one put 17x8 with 255/45ZR17 98W BSW on their XJS
has any one put 17x8 with 255/45ZR17 98W BSW on their XJS?
Will they fit?
Old 12-01-2014, 07:46 AM
calvindoesntknow's Avatar
Tire size is good. What is the offset ofthe wheel?
Old 12-01-2014, 03:30 PM
ronbros's Avatar
Received 1,231 Likes on 939 Posts
i used 18/9 frt wheels, 18/10 rears, ENKEI, with a spacer(mine is not an all out race car).
Nitto 295/35/18 rears,, 275/35/18 frts. KDWs.
Attached Thumbnails has any one put 17x8 with  255/45ZR17 98W BSW on their XJS-003.jpg   has any one put 17x8 with  255/45ZR17 98W BSW on their XJS-jag-rodstr-015.jpg   has any one put 17x8 with  255/45ZR17 98W BSW on their XJS-mazda-jaguar-001.jpg
Old 12-01-2014, 07:11 PM
Jonathan-W's Avatar
coventry hornet wheels 17x8 high offset
Old 12-02-2014, 04:26 AM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
I have 16x8 with 245/50 16 offset front 20 rear 33
If you get the offset right then 17x8 with 255 should fit without rubbing so long as you do not lower the car.
Attached Thumbnails has any one put 17x8 with  255/45ZR17 98W BSW on their XJS-dscn0967-1.jpg
Old 12-02-2014, 10:53 AM
Japthug's Avatar
Mine is fitted with 255/40R18 8.5J +33 on rear.
I googled coventry hornet, it says the offset is +25, I doubt it will fit with a 255 tire. a 245 should be alright.
I once checked mine but I didn't think there was 8mm more space.
Old 12-02-2014, 12:05 PM
Jonathan-W's Avatar
that is right for the LOW offset the high off set is + 42mm
and both are the same rim coventry hornet
High offset
17x8 +42 offset
Old 12-02-2014, 12:06 PM
Jonathan-W's Avatar
that is a beautiful car!
nice flare in rear!
ronbros (12-02-2014)
Old 12-02-2014, 01:57 PM
Japthug's Avatar
High offset
17x8 +42 offset
I think it will be alright.
The inside of the tire might rub inner side of the fender wall, but can be avoided with a 5mm spacer or something.
The following 2 users liked this post by Japthug:
Jonathan-W (12-02-2014), ronbros (12-02-2014)
Old 12-03-2014, 04:04 AM
warrjon's Avatar
High offset
17x8 +42 offset
A 8" wide 42mm offset is too large you might find the inside of the wheel rubs where the 2 panels are swaged.
8.5" with 42 should JUST fit but might be close.
Old 12-03-2014, 08:38 AM
Japthug's Avatar
Today I checked my car.
I think there is more than 10mm space inside, but mine is 18 rim and if it is 17 the wheel rim might rub the bump stop rubber even if the tire doesn't. So the spacer will be needed if you want to fit a 42 offset rim.
Old 12-04-2014, 11:07 AM
Jonathan-W's Avatar
Thanks!
Old 12-10-2014, 09:35 PM
88-xjsv12's Avatar
Ive got a set of eplsions 16x9.5 Im going to put on her is a 35 offset of 35 on the money?
Old 12-11-2014, 12:11 PM
Stargazer XJS's Avatar
The last time I researched Coventry wheels, they didn't offer a wheel with a bolt pattern compatible with the XJS - what did you have to modify, if anything, to get the Hornets to fit?
Old 12-11-2014, 02:43 PM
warrjon's Avatar
Its not just the bolt pattern (PCD) the XJS has a 74.1mm center bore and 5x120.65 PCD. BMW used a 74mm center bore on the E39 & PCD was 5x120. Wobbly nuts can be used if they are legal where you live.
Wheels can be modified, center bores reamed and PCD changed from 5x120 to 5x120.65. In some places like Australia spacers are illegal so have the wheel modified with an insert bolted to back of the wheel to change offset.
Any non XJS wheel will require some modification. Even if it is only spacers. XJ40/X300 wheels fit with spacers for the front.
ronbros (12-11-2014)
Old 12-22-2014, 01:00 PM
jpitma1's Avatar
I have 235 50s on 18" Coventry Whitleys. Yes, Coventry makes the perfect wheel fit for an XJS; no modifications or adapters required. Mine just barely fit without rubbing the inner fender liner.
Old 12-27-2014, 07:05 PM
jpitma1's Avatar
Correction! My tires are 235 45 18!!!!
ronbros (12-28-2014)
Old 12-28-2014, 09:02 AM
ronbros's Avatar
my tires are 275-35-18 frt,, 295-35-18 rears, and dont rub lock to lock!
been 20 yrs ,Maybe i was ahead of the curve back then, should i go to smaller tires?
this whole thing about tires and wheels is just a personal thing, and something to talk about.
to each his own, really all they have to do is go down the road, and make the owner happy!
Old 12-29-2014, 01:13 PM
Jonathan-W's Avatar
Wheels that the tires go on are?
and do you have pictures?
Old 12-29-2014, 05:53 PM
ronbros's Avatar
Jon, post number 3, wheels are ENKEI. 9frt,, 10 wide rears. Pix.
mbergen
10-23-2019 10:26 PM
PMKimpton
08-03-2019 08:22 PM
dsnyder586
04-04-2019 02:38 PM
deanh
09-06-2015 08:20 PM
SouthernGypsy
09-03-2015 10:54 AM
Quick Reply: has any one put 17x8 with 255/45ZR17 98W BSW on their XJS
