Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Classics ) > XJS
Sign in using an external account
Register Forgot Password?
Search
XJS 1975 - 1996 3.6 4.0 5.3 6.0
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
Headlight/fog light issue
LinkBack Thread Tools Search this Thread
Old 07-25-2013, 12:09 PM
Lightbulb Headlight/fog light issue
Here are the symptoms:
low beam headlights are very dim (much more than the usual weak light) but both illuminate.
fog lamps do not work at all
fog lamp switch will not illuminate when pressed
high beams work fine
Any assistance with a diagnosis sequence is greatly appreciated. I checked all system fuses and they are all OK,
Thank you very much.
Dave
Old 07-25-2013, 12:32 PM
AllanG's Avatar
Are the headlamps the same brightness wether or not the engine is running?
Also the the headlamps must be on dipped (main) beam for the fog lights to work.
Cheers,
Allan
__________________
Cheers,
Allan
1994 XJS 2+2 Conv 4.0L Factory 5 speed with SportsPack
1995 XJ6 Vanden Plas
Old 07-25-2013, 01:32 PM
I suspect you have more than one problem. What year is your car? The later models had a small pilot light in the headlight assembly. If your main lights are burnt out, you will only see the smal light.
As far as the fog lights, check the fuse and the relay. The relay is under the hood and the terminals do get dirty.
__________________
Maynard
94 XJS 6.0 Coupe
91XJS (RIP)
78MGB
67MGB
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
