Help. Front hub outer bearing
Old 06-14-2014, 02:15 PM
Bc xj's Avatar
Default Help. Front hub outer bearing
I need help. I tried to remove outer bearing race and it came out but it was attached to some kind of spacer. Do I remove race from spacer then locktite spacer back into hub? Is the hub shot? Is this normal?
I cant find outer bearing and seals locally as the cross reference guide is wrong. Does anyone have bearing and seal part numbers.
Old 06-14-2014, 02:55 PM
Greg in France's Avatar
Received 9,076 Likes on 5,344 Posts
Can you post a photo of what you are describing, please?
Greg
Old 06-14-2014, 08:40 PM
Bc xj's Avatar
here are photos of the part. is this race in some kind of spacer? is this part of the bearing? Im confused.
Attached Thumbnails Help. Front hub outer bearing-photo-1.jpg   Help. Front hub outer bearing-photo-2.jpg   Help. Front hub outer bearing-photo-3.jpg
Old 06-14-2014, 10:38 PM
Received 10,283 Likes on 6,804 Posts
Oh dear, I need a drink.
That bit in #2 looks like the cup of the bearing, and is ALWAYS a press/tight hammer fit in the hub. If that came out as easy as that, it has "spun" in the hub at some time in the past, and the hub is basically toast.
I have a Timken parts book somewhere, and when I finish the front wheel bearing on the S Type, I will look for you and post back.
Old 06-14-2014, 10:58 PM
Found it.
Front Outer is Set12, which comprises LM12749 & LM12710 (same as Aussie Ford).
Front Inner is Set13, which comprises LM68149 & LM68110 (Jag specific for the LM68110).
Front seals = 473454.
Any half decent Parts mpb, bearing supplier, will have the bearings in stock, seals, dunno.
Your location I assume is USA?, so try SNG Barratt on here, in the USA, as they often have front wheel bearing kits, including seals for minimal $.
Old 06-15-2014, 12:40 AM
Bc xj's Avatar
The inner bearing is a 13. The outer states a 12 but it doesn't fit. The inner diameter is just a bit to tight and the outer diameter is quite a bit smaller. My car is an 89 xjs with abs. Jagbits claims to have right part so I will try them.
This pic is the bearing I found in there. The spindle is 2/3 s of bearing inner diameter. What were they thinking.
Old 06-15-2014, 02:19 AM
Does this mean the hub should be replaced as well as the bearing, Grant?
Greg
Old 06-15-2014, 03:40 AM
Greg,
If that bearing has spun in the hub, then YES. If the race has spun on the spindle, then the spindle needs replacing also. Sense of humour goes South real quick when a spindle breaks, and they do break.
The chart I used is for that year model, and is the same bearing combination right to, and including, X300. Did the Green Beast a few weeks ago. They went to "Hub Type Sealed" units from then on, big$.
I have refitted bearings into spun damaged hubs, purely as a get me home fix. Mainly on my Road Train (3 trailer semi trailer outfit unique to Aussie's). Never on a Jag. That Steel Stick stuff is a wonderful product, but not a permanent fix by any stretch of the imagination.
Old 06-15-2014, 06:39 AM
texasscot's Avatar
Fwiw, I'm doing my 90 abs front hubs at the moment, bearings were fortunately fine but needed new seals. As far as I can see, all parts houses list TIMKEN Part #473454**{#C45711} for this but it is incorrect. They are around 0.1 inch too large (I bought them and tried to fit). I think the ones you need are BECK/ARNLEY 0523413 (052-3413), I'll be getting these on Friday so will not be able to confirm until then.
Of course if you get the sng kit you won't have to worry about this.
Old 06-15-2014, 10:28 AM
Bc xj's Avatar
So is this whole thing part of bearing race. It looks like the race was in this piece (photo 2)
Old 06-15-2014, 08:35 PM
The wheel bearings are a 2 piece affair.
Commonly called "cup and cone".
The part with the tapered rollers also incorporates the "inner" section that fits over the spindle, then the mating "cone" sits into the hub. The 2 mate "cup and cone", with extremely fine tolerances to give the required support for the hub.
There is a cup and cone on the inner side of the hub (usually larger than the outer), and then the same arrangement on the outer (the one you show is the outer).
The parts drawing shows NO detail, so I have not attached it. I will look in a bearing book at work today, and if there is a better schematics will copy it and post back tonight.
Old 06-15-2014, 09:59 PM
texasscot's Avatar
Bernard Embden's excellent website has a good description of a front hub rebuild with photographs.
http://www.bernardembden.com/xjs/hub/index.htm
Old 07-24-2014, 06:10 AM
texasscot's Avatar
Just to round this off, here is a picture of the XJ-S 1990, with ABS, front hub seal information.
graham
The following 3 users liked this post by texasscot:
Bc xj (07-24-2014), bullittandy (05-01-2016), Dukejag (07-08-2019)
Old 07-08-2019, 02:44 AM
Dukejag's Avatar
I had my front end up in the air over the weekend and checked for any play on the front wheels, nothing on one wheel and a small amount on the other.
But very noticeable.
So my choice is to tighten the wheel bearing, or try. Or replace both. 1988 XJS.
Or..........
Old 07-08-2019, 02:54 AM
Just tighten the loose one a touch; just up to "no play" and NO tighter.
The following 3 users liked this post by Greg in France:
Doug (07-08-2019), Dukejag (07-08-2019), Grant Francis (07-08-2019)
Old 07-08-2019, 05:25 AM
baxtor's Avatar
Received 1,122 Likes on 730 Posts
Or..........
Odds of worn stub axle are just as good as worn bearings. Try adjusting current bearings correctly and checking for play before going the new bearing route.
Old 07-08-2019, 06:26 AM
Doug's Avatar
Received 10,741 Likes on 7,097 Posts
I'll ask this just on general principles because this routine service procedure is all too often neglected.....
When was the last time the hubs and bearings were removed for cleaning and re-packing?
Old 07-09-2019, 03:30 AM
Dukejag's Avatar
Doug,
Not by me so no idea, only owned this car for one year... the list of repair / check stuff just gets longer and longer...LOL
I will report back after pulling the wheel and having a look.
Thanks all for the info.
Old 07-09-2019, 06:02 AM
leo_denmark's Avatar
Hi
inspired by this thread I pulled LH front hub yesterday. Doesn’t look to bad, but my stub axle surely has wear at the underside at inner bearing.
Outer bearing
Old 07-09-2019, 07:07 AM
baxtor's Avatar
Originally Posted by leo_denmark
Hi
Outer bearing
If you reassemble and nip the bearings up all the way you may find you still have some 12 o'clock 6 o'clock play. It takes very little wear to the stub axle to upset the apple cart. I would not be afraid of using loctite on the inner bearing.
leo_denmark (07-09-2019)
aholbro1
08-05-2021 05:02 AM
PMKimpton
08-03-2019 08:22 PM
Joey T
09-03-2015 05:31 PM
Harry Dredge
09-03-2015 03:04 AM
innzane
09-02-2015 10:08 AM
Quick Reply: Help. Front hub outer bearing
