Hood alignment
Bc Xj Yes, I can imagine that too. In fact I took a little grinding tool and rounded the ends of the little bars that are mounted on the bonnet so they will slide out of the latches even if closed. I would still have to remove the hinge bolts but it will be mush easier after that.
Cheers, RagJag
Cheers, RagJag
There are three ways to skin this cat or pooch: 1. Buy spring loaded latches. 2. Add a spring, latch to body 3. Drill a small hole in the latch and run a wire to the bottom of the firewall
I like #1, . There are two possibilities of failure of cables. they break or loosen in or come out of the cable stops. Ragjag is right; trying to remove eight bolts from under the car and in there location would be extremely difficult.
(As an aside. does any one know where to buy the cable stops. I brought one to a good size bicycle shop and drew a blank) 0
