I need help choosing the right tire.
Hi,
I just recently got a set of the starfish rims. I was using the 16" lattice rims with 225/60 tires. Now that I have the starfish rims I notice that the factory tires size is 215/70vr/15. When looking for tires the only options are S and T speed rated. I do like the look of BFG Radial T/A tires, but I not sure about the speed rating. The stock Pirelli's where V rated I believe. Should I try and get a higher speed rated tire? Will it make that much of a difference? Is it too risky to drive on S rated tires with this car?
Any help with this is greatly appreciated.
Thanks,
Jake
Thanks,
Jake
Hi,
Thanks,
Jake
Thanks,
Jake
Jake, its funny I'm working on exactly the same thing. Car I just purchased has a set of chrome knock-offs that were not my style, so I'm reverting back to the starfish as well. Unfortunately, the only 215/70vr/15 tire available is made by Michelin, called the XWX. Its about $2k for a set unfortunately. But near as I can tell, and Doug on here confirmed, that is the ONLY 215/70/15 tire still for sale with a v speed rating
That is unfortunate. I am tempted to go with the Radial T/A's, I have seen other XJS owner use them. However I am somewhat apprehensive to the idea of S rated tires. I do like to drive fast. Not really around corners as much, but I'll cruise the highway at 80-90mph at times. I hate to think of what would happen should those tires not be able to handle that.
That's for the lattice rims. I have the starfish rims. Which came standard with 215/70 vr15. I don't know that 235/60 VR15 would fit on starfish rims.
My understanding is that the lattice wheels were standard from 89 to 94, shod with Pirelli P600 tyres.
I don't think you would have a problem putting 235/70 tyres on the starfish as both the starfish and lattice wheels are 6.5J x 15
Yes the 215/70VR15 were standard on the 87 and 88 models. The lattice wheels were optional on the 88MY with 235/70 tyres.
Good thought though
Tire Choices
-I'm considering changing up my tire sixe from the 235/60-15 on stock Lattice rims on my '89, to an after-market 16" rim with 225/60-16 tire, as the tire heights are 26.1" dia(15") to 26.5"(16") -I punched these tire sizes into Costco.ca on-line, and they have a Michelin tire, and two BFG, the Advantage T/A comes in a V rating for $167 +$15 Installation.
Received 10,747 Likes
According to the speed rating, yes!
One thing you can do is look for the highest possible load rating. Load rating and speed rating are two different things but a higher load rating tire will generally have a stronger casing, which should make you feel a little better
Probably even safe for over 112-118 mph for short periods...although one hates to take chances at those speeds, of course. Crash at that speed and you're toast. But, it's not like a bomb necessarily goes off the minute you hit the speed rating.
Look at the tires we used to run on ages ago. I can remember going 120-130 mph on 'Goodyear Polyglas GT' tires in the 70s with no qualms. They didn't even *have* a speed rating! It was a good tire in the day....but I reckon most any tire made today is light years ahead of it.
That's a good point about the load rating.. I'll take a look at that. Right now I'm leaning towards the Michelins I mentioned earlier in the thread. Best buy short of the XWXs.
