1976 XJS v12 EGR solenoid
Hello i had a bit of a rough hot idol issue and found one EGR valve cartooned up and stuck shut but the solenoid worked when 12 volts applied
on the other side the valve was open but the EGR solenoid is seized it looks like a sealed unit
question
is there a way to get this apart and bench repair it or dose anyone know where i can get a replacement new or used
thanks Ken
question
thanks Ken
Welcome to the forums Ken,
I've moved your question from Canada Region to XJS forum. Members here with the same model will be able to help.
