Mystery cable
Old 11-24-2014, 07:29 PM
afterburner1's Avatar
Default Mystery cable
This is a mystery question pertaining to the possible installation of an older Cell Phone in circa 1993 into a 1993 XJS Coupe The cable is just left of the left fuse box.
I am new to this car and found a four wire shielded cable with a red, black, slate. and a braided wire plus the shield. It is alleged that there could have been a cell phone installed in the car. Black and red wires are usually power lines and the braided wire acts as shielding. I don't know the usual purpose of the slate wire. Does anybody have a clue on the use of this four wire cable or suggestions on its use?
Old 11-24-2014, 09:30 PM
sidescrollin's Avatar
left of the drivers side fusebox sounds more like the location of a security device to me
afterburner1 (11-29-2014)
Old 11-25-2014, 10:14 AM
RonaldP's Avatar
My 95 has the factory wiring harness in the trunk, actually there are two harnesses. both have Jaguar part numbers. I have coiled them up together and tucked it away behind the driver side rear wheel well. My console top was recessed in the center for the hand set. So I believe all wiring was to the rear of the car and would not have been connected to any fuse boxes in the forward sections. I replaced my console lid and you would never know it had been there.
Old 11-26-2014, 01:04 AM
At least one of those rear harnesses is for the cd changers. Luckily my phone got mounted on the passenger side kick panel, so it isn't too noticeable
Old 11-29-2014, 07:51 PM
Perhaps my description lacked clarity.. The cable that contains the wires is to the left of the driver side fuse box in the cabin. The wires have been stripped by a previous owner, but it appears to be a factory cable. I have no idea where the cable starts......
The left blower motor does not function, but I don't think that these wires are associated with the blower circuit; I could be wrong???
I thank you all for your replies!
Old 11-29-2014, 11:36 PM
Including the tracer, what color are the wires?
Old 12-01-2014, 08:07 PM
Colors are blaxk red and white, none have a tracer. There is a braided wire in addition to a braided sheath. The cable has a black cover. The previous owner striped the wires and left ends uncovered.
Old 12-10-2014, 03:05 PM
RonaldP's Avatar
sidescrollin... I have the CD changer in the trunk (boot) the two harnesses are both for a telephone. There were two different phone manufactures offered is my guess. They both reference telephone equipment on the tags. It was two years ago when I was working on it and I don't remember which phone manufactures they referenced. Of course at my age I eat the same breakfast every day so if someone asks what I had for breakfast there is a 50 50 chance I can answer that...
jimforrest (uk)
02-28-2019 06:42 PM
adam699
10-13-2015 05:53 PM
tomkilner
10-09-2015 07:10 AM
10 XF Premium
10-02-2015 09:22 PM
Quick Reply: Mystery cable
