Pinout for abs solenoid plug
Old 10-14-2014, 04:05 PM
sainmatt's Avatar
Default Pinout for abs solenoid plug
Does anyone know which side of this 7 pin connector is ground? I'm about to test the operation of my solenoids and I was curious if anyone knew.
Thanks!
Old 10-14-2014, 11:02 PM
sidescrollin's Avatar
Wish I had a newer book, but I don't have any stuff for ABS cars. Just grab a multimeter, hit one in on a good ground and the other on all the pins. Whichever one has no resistance is your winner. Generally you are looking for a black wire.
After digging around it seems it should be a black wire on the far end of the connector. Not sure which end that is. The opposite side is white with a red tracer if that helps.
Old 10-15-2014, 12:03 AM
sainmatt's Avatar
Thanks for the image!! My meter unfortunately crapped out on me. It was measuring continuity to the engine block on all the pins which i thought was a little strange.
Maybe it will decide to work in the morning.
Does the jag have a ground to the engine block by default? Otherwise, where is a good ground point under the hood?
Old 10-15-2014, 01:19 AM
just grab any unpainted metal attached to the body. Closer up front the cover running over the radiator has a grounding point thats easy to use and further back towards the fenders you can probably just use any bolts going through the fenders or maybe the bolts in the braces.
ericjansen
12-19-2021 12:20 AM
skyryder
03-25-2016 08:18 PM
flyrr100
09-29-2015 03:47 PM
mrplow58
09-15-2015 09:58 PM
tsimms7
09-15-2015 12:43 PM
Quick Reply: Pinout for abs solenoid plug
