Potentiometer Replaced; New Problem Uncovered
Old 07-27-2014, 09:02 AM
Vee's Avatar
Vee
Vee is offline
Received 1,508 Likes on 1,175 Posts
Default Potentiometer Replaced; New Problem Uncovered
1996 XJS, AJ16
OK, so I spent the weekend replacing the potentiometer. I have attached a picture and I think that might have been part of the problem... Somoene, or something expanded the holes used to bolt that part in.
While in there, I recleaned the throttle body, the stepper motor, the EGR valve and I also reseated new gaskets to the spark plug cylinders.
Turned the car over and now I have a rough idle, but smooth drive. It no longer chugs at speed, but I was experiencing intermittent stalls.
I hooked it back up to the computer, and the MAF sensor was acting up. As soon as I unhooked the MAF sensor, smooth idle returned. The car was at temperature.
I guess I'll give cleaning the MAF sensor a go. If not, I think I'll have to look for a replacement?
Is there anything else I should be checking?
Old 07-27-2014, 11:11 AM
icsamerica's Avatar
Received 1,359 Likes on 790 Posts
make sure the air duct between the MAF and throttle body is in good leak free condition.
Old 07-27-2014, 12:40 PM
Vee's Avatar
Vee
Vee is offline
I just went through it and could find no leak.
I did get a P1316 code flash up! It's strange that it wasn't paired up with another code.
I will have to take it out for a solid drive and see if I can't burn out all of the solvents I used, either that or force that car to tell me which cylinder is causing the problem!
fast40driver
Yesterday 07:24 AM
X_Type_South_Africa
12-09-2015 05:37 PM
Fraser Mitchell
10-01-2015 04:06 AM
johanasu
09-03-2015 12:39 PM
martybmw
08-31-2015 08:41 AM
Quick Reply: Potentiometer Replaced; New Problem Uncovered
