quad turbo XJS build
#41
The first time Ronbros mentioned this I looked on ebay and saw just an engine at $10k. No telling what the final bidding went up to. But yeah, it's an intriguing swap. I haven't seen one for sale since...
#43
#44
#46
Greg in France (11-09-2014)
#47
Received 1,231 Likes
Audi Q7 SUV TDI, but says V12 on the front and rear, we get them in usa 3.0L V6 TDI, no comparison of performance. never said they are cheap,yno, you get what you pay for.
Utube some of them, some of them matching BMW M5 petrol, but way better mpg.
Diam , you think your V12 XJS is not a polluting engine? and your mpg aint all that good.
#50
#51
#52
#53
Your larger head studs may fix this though.
#54
I just made the assumption because he talks about compound boost, one turbo feeding into the other.
#55
Correcting the problem would more than likely involve tightening to plastic deformation instead of elastic, in other words, torque to yield bolts.
#56
lag
compound turbos is NOT like sequentual.
with sequentual 1 turbo cuts out then second cuts in.
Creating lag in the change over phase.
With Compound all turbos run all the time.
small primaries bleed off to prevent overspool while feeding directly in the large
before exiting the car. large turbos feed boost directly into primaries to double boost pressures (sort of) so even at lower rpm you can still maintain even boost.
Just got back into the country after flying to SA for wedding then bali for holiday then UK for funeral so at this stage my funds are well in the red.
Got the repaired lathe motor in and wired backup. just need to reposition lathe back into its slot to commence work again.
Hope all is well with every one and jags not dieing ungracefully
ronbros (11-10-2014)
#57
Head studs stretch under normal conditions regardless of power, positive pressure (boost), just makes it worse. A stud such as ARP would need to be used in any motor that's making any sizable amount of boost.
The next issue to consider is the floating liners, not sure longevity would be on your side without evaluating the same under boost. I've lifted heads on approx. 25lbs of boost (proper head studs, etc.), evac'd an entire coolant res in the process too (that'll get your attention, thankfully was on a dyno). ;-)
As for the Legacy being laggy, am assuming your displacement was fairly low. The 5.3, if matched to the proper hot side, should be lag free, stepped turbos, even better.
Cheers,
Jeff
Cheers,
Jeff
ronbros (11-09-2014)
#60
a few yrs back on this site, i tried talking about rear mounted twin turbos in the area where the mufflers used to be. most said noway wont work, much turbo lag.
i have done 4 vehicles with remote turbos, they all worked very well ,its all about sizing and tuning. easier than you think.
frees up a lot of under hood room, and big reduction of under hood HEAT, little short pipes out the rear off the turbos, sound nice no mufflers(turbos act as a muffler).
well google KIA 900 twin turbo, or LUX motorwerks(they did the mods).
