refurbished V12 fuel rail.......
Old 03-04-2008, 04:14 PM
Brake buster's Avatar
Default refurbished V12 fuel rail.......
hi, i have a 1989 V12 coupe , and am three years into the restoration,
this time the engine gets some attention
my existing fuel rail is not in the best condition , as its been on the car for eighteen years now, and one or two of the fuel pipe links to the injectors have been ' repaired ' the wrong way ( PO did it before my time i'm afraid )
so , with a similar replacement fuel rail in hand i set about refurbing it, first of all the twelve injectors had to be cut from the link pipes, this was easy enough , but the removal of the old hard pipe from the ferrules was a lot harder , and took some care and time, with all of them removed i set to with the wire wheel and dremel , and masked up the ferrules and fuel inlet back nuts
once i was happy with the condition i coated it in acid etch primer, and then a metallic silver base coat , and then two top coats of lacquer
once dry the masking was removed
i got two meters of 5/16 injector fuel hose last year, and bought some new caps from Jaguar Heritage last week , and made up 10-45mm and 2-95mm lengths of hose , and put on the caps ready for pushing onto the fuel rail
the pipes pushed on quite easy with a twisting action , making sure the caps were on and in the correct position , as removal would require cutting off :?
just waiting to get the injectors serviced now, and will push em on with the back collars ready for installing in the car in the near future
BB
The following 3 users liked this post by Brake buster:
gregh (04-09-2013), JakeM. (04-11-2013), someguywithajag (07-30-2018)
Old 03-06-2008, 09:50 AM
ken@britishparts.com's Avatar
Default RE: refurbished V12 fuel rail.......
You are a lonely, very sick man.[&o]
Nice work!
Old 03-06-2008, 12:57 PM
Don,
your in luck, i'm building another one, exactly the same
whats it worth to ya, lol
BB
Old 04-09-2013, 03:20 AM
8aric8's Avatar
Default Sweet
Post some pics once its back in . I just got done cleaning mine up and was wondering what tone of silver to coat it with, so forgive me if there is a copy cat XJS cruising around soon awesome job man!
Cheers!
Old 04-09-2013, 04:03 AM
rgp's Avatar
rgp
rgp is offline
I found zinc plating/dipping as original is still inexpensive providing you do the cleaning..
FerrariGuy (05-26-2022)
hunter34
19
09-14-2022 11:09 PM
JWheeler
11-22-2019 08:28 AM
dsnyder586
04-04-2019 02:38 PM
Mac Allan
09-11-2015 10:27 AM
prettydaim
09-10-2015 04:27 AM
Quick Reply: refurbished V12 fuel rail.......
