Seat Belt components
My 96 XJS 2+2 Convertible needs a seat belt component.
My drivers side seat belt shoulder strap blade will no longer lock in the female portion.
I have pulled it all apart and see that a piece of white plastic (Looks either broken or worn down) that slide up and down depending on blade insertion pushes against the metal locking component and locks into the blade.
I noticed that the seat belt is an old Allied Signal assembly.
Does anybody have any ideas on whether components are available?
I noticed that entire units are on sale for $$$$$$. I temporarily took an off the shelf locking device and connected it in.
I managed to get it all apart without any issues.....Just need that piece of plastic to reassemble and make work like new!!
Any ideas/suggestions are appreciated.
Softball60 Paul
1996 XJS 2+2 Convertible
1957 XK140 Drop Head Coupe
1989 Mercedes 560SL
Softball60 Paul
1989 Mercedes 560SL
Can you temporarily put the passenger side receiver onto the driver side while you look for a solution so you can at least drive safely?
Keep this in mind if you look for a used replacement part. If they are interchangeable it would be wise to use a passengers side buckle because it would be less used. If the internals are in the same in the rear, you may be able to bust open the rear receiver and replace the worn part in yours. Just put the rear back together, who cares if it works.
Sidescrollin,
Thanks for the suggestion. I did temporarily replace the drivers side receptacle with an off the shelf unit that works. Still want to find the parts of salvage yard replacement.
I will look at the back as a possible solution. The only issue is then the back will not work......Trade off....??
Softball60 Paul
1996 XJS 4.0L 2+2 Convertible
1957 XK140 Drop head Coupe
1989 Merc 560SL
Softball60 Paul
1989 Merc 560SL
Sidescrollin,
Thanks for your patience. I was not aware of this site. How do you get to it normally when looking for parts. It looks like it is a British site.
Anyway You may be correct. I might be able to take apart and insert into my assembly.
Paul
1996 XJS 4.)L 2+2 Convertible
1957 XK 140 Drop Head Coupe
1989 Merc 560SL
Paul
1989 Merc 560SL
A few sellers on the UK ebay site have the female bit as new old stock. You could replace the complete broken part. Just depends if they have your colo(u)r this week........
US site
http://www.ebay.com/sch/i.html?_from...+belt&_sacat=0
US site
42Ajd
12-30-2015 09:45 AM
beady
09-28-2015 10:20 AM
FS[MidAtlantic]: 1997 XJ6 VDP - Very RARE Black on Black
42Ajd
09-21-2015 07:37 PM
