Window problem
Old 07-22-2014, 01:10 PM
Greg in France's Avatar
Received 9,077 Likes on 5,345 Posts
It does look like it. just to be 100% sure, disconnect the motor at the connectors and test the entire switch circuit by putting your test light where the motor would be. Assuming all well, how easy does it look to remove the motor? Once off, squirt 12v though it to check it before throwing it. No idea what new ones cost or even if available, but Grublogger will have one.
When replacing the card, getting the middle of the card clip in place is a bit of a sod. The card has to be pushed inwards as well as downwards quite firmly to engage it. If you have not engaged it, the card middle will flap about so you will know...
Greg
orangeblossom (07-22-2014)
Old 07-22-2014, 01:33 PM
orangeblossom's Avatar
Received 3,740 Likes on 2,593 Posts
Greg
Hi Greg
Disconnected the Wires 100% Juice getting to the motor.
Even hard wired it to a 12volt Battery but no dice!
Old 07-22-2014, 01:43 PM
jimbov8's Avatar
Just a thought OB while you are in there. Give the motor a slight tap and then try moving the motor drive manually. Then try powering it up.
It may just be stuck or one of the brushes may not be making contact.
May save you a few bob if it is.
Old 07-22-2014, 02:19 PM
OMG! I did that and its Working!
I hit the metal panel with a big rubber hammer and it WORKS!
Thank You So Much!
You have just saved me a fortune!
Old 07-22-2014, 02:25 PM
jimbov8's Avatar
Glad to hear it and to be of some small assistance.
Old 07-22-2014, 03:30 PM
In that case I wonder what Big Assistance is like!
The Jaguar Gods were with me!
Thank You Again!
jimbov8 (07-22-2014)
Old 07-22-2014, 03:43 PM
OB
Proceed as follows:
  • Disconnect battery
  • Open door and unscrew from the door front end the chrome striker plate that operates the courtesy light switch
  • ease back the chrome ferrule that is round the thin end of the armrest. Under this is a HUGE pozi screw that you must undo
  • under the door pocket front end is a well hidden screw, undo it
  • then go round the door car and pop out the trim clips that hold the card edges in place. Start at the bottom front and work up the front vertical edge to the window, then go along the door bottom and up the rear edge to the window
  • the car is now held in place by a large clip in the middle and by the edge along the window bottom. A GOOD vertical upward sharp clonk with the base opf the hand on the card will pop these free. CAREFUL as the door card is attached to the speaker wires and the courtesy light wires, AND in your case it being the driver's door the mirror switch wires.
  • disconnect these carefully at their plugs. Get the GF/postman/passer by etc etc to hold the card while you do this as you will need two hands.
Now you can see the winder and its motor, JUST. I have not got a photo of the door inside handy, but when you get the card off, post one if you want more help. I cannot remember exactly where the motor is, but the window mechanism as a whole bolts into the door on a large roughly rectangular plate, and it will be there somewhere!
I suggest you make 100% sure that the leads that attach to the motor have power from the switch before you strat undoing anything in the door!
Good luck, but I have to say you tempted the XJS Goddess by starting to think about bling - keeping the lady happy in standard form is usually quite enough strain on self, bank account and patience!
Greg
In that case I should start with one of these!
Record-breaking fuzzy dice rolled out in Las Vegas | Guinness World Records
  #28
Old 07-22-2014, 06:10 PM
Steve M's Avatar
Received 2,904 Likes on 1,660 Posts
When all else fails, **** it with a big hammer!
Glad to see that this still works.
The following 2 users liked this post by Steve M:
dickc (07-26-2014), orangeblossom (07-22-2014)
Old 07-22-2014, 06:21 PM
Thanks Steve
You and me both, that could have been a very expensive day out!
  #30
Old 07-23-2014, 12:39 AM
Love it, GREAT fix. Nothing as satisfying (on a ca) as hitting something with a hammer and making it work!
Greg
orangeblossom (07-23-2014)
  #31
Old 07-23-2014, 02:16 AM
Greg
Not forgetting your much needed help, in guiding me through the fault finding technique to actually get to that point.
I didn't even hit it very hard!
99xk8guy
06-05-2023 06:28 AM
99xk8guy
09-21-2019 07:34 PM
GordoCatCar
01-02-2017 01:10 PM
fingers
General Tech Help
10-21-2015 02:02 AM
laserguy
09-03-2015 02:02 PM
Quick Reply: Window problem
