Changing air filter on 4.0 engine
Old 12-15-2012, 04:12 PM
Scotlad's Avatar
Default Changing air filter on 4.0 engine
I have a 93 XJS with the 4.0 engine, is there an easier way to change the air filter than removing the air intake on the throttle body and removing the air filter canister? The same year of XJ6 with the same engine uses a much simpler modern canister that just unclips to replace the filter. This is my first vehicle I have had that makes changing or even checking the condition of the filter such a hassle.I have heard some other European cars have similar systems.
Old 12-15-2012, 04:20 PM
Steve M's Avatar
Received 2,914 Likes on 1,665 Posts
You can bin the whole lot if you want to and fit an after market conversion which makes it a lot easier.
I think that AJ6 Engineering do a kit.
Series1fan
09-05-2015 08:02 AM
dwgates
09-02-2015 04:09 PM
1964Daimler
08-31-2015 06:41 AM
MrMellor
08-29-2015 10:26 PM
dpappyp
08-27-2015 06:31 AM
Quick Reply: Changing air filter on 4.0 engine
