1989 XJS Bosch Alternator Wiring Please Help
This and brakes, and, my car is running and driving! A mouse, or mouses, chewed the alternator wiring. It is a Bosch with load dump module. I have 2 loose ends, the "exciter" wire that runs down the fender to the alternator, from the dash light, and, one end of the load dump module. I think that the load dump is just grounded to body, correct? Also, I hope I have my ground wires on the proper terminal. The ground wires are on the terminal just to the right of the B+ terminal, which has the starter wires on it. So, I am asking, where does the "exciter" wire go, where does the end out of the load dump module go, and, what terminal do the ground wires go on? Please, help, I can't find this info anywhere. Thanks.
I have a oneline for a 1989 XJS listed on my page I hope that helps.
gthawk1 (01-20-2014)
try this link, although I don't have a 'w' on mine
Bosch(?) alternator wiring query - International Forum - LR4x4 - The Land Rover Forum
well mine has 2 push on spade terminals that go on the large 'B' terminal in picture they both run to the starter motor in a conduit bolted to the side of the engine, although you may only have one on yours, the warning light is a small push on 'D+' and goes to the side firewall (flitch).
I have no 'W' terminal. I don't know the word exciter but I only have the three wires and they just use the 2 terms. surrounded by black plastic
hope this helps
the best pic. I can get of it sorry about the claret
hope this helps
gthawk1 (01-22-2014)
Discouraging session. I hooked up the wires, the light on the dash that has a battery on it came on, and, the gauge indicates 12 volts. My only thought is why did I double ground it? The dump load box is grounded, plus, there is a ground from the same terminal to the same body ground bolt. Wouldn't this circumvent the dump load module? Or, a bad alternator. Or a bad dump load module. ????? Any thoughts would be appreciated, you guys got me this far.
vinny jones
10-05-2015 07:20 AM
