89 xjs v12 please help!!
Hi guys im really hoping someone can help me, the drivers door handle on my 89 xjs got stuck "up" and the drivers door wouldnt close. Now the bigger issue is this, both doors are now closes (unlocked) with the handles jammed AND the keys in the car!!!! So im locked out of my xjs and really dont have a clue what to do!
I really want to abvoid breaking a window as im worried about the cost to have a new one fitted can anyone please help
Greg
Have you got windscreen cover on your insurance?
If you do have to break a window don't do one of the door ones because you'll have to strip the door down to remove all the broken glass otherwise it will bugger up the door and window mechanism.
Have you tried spraying the handles and locks with WD40 or similar? let them soak overnight and try again in the morning.
If you can get a coat hanger inside the car you might be able to hook the inside door handle.
If you can get a "slim jim" down to the door latch you might be able to unlatch the door. Here is a drawing that shows the locking mechanisms and rods. If you can pull on rod #9 it should unlatch the door.
Mark
Mark
