ABS wheel sensor - compatibility
Old 05-26-2015, 11:34 AM
MHF25's Avatar
Default ABS wheel sensor - compatibility
LH front ABS wheel sensor. Is a DAC4841 - XJS Vin up to 198334 compatible to a DAC1115 - XJS Vin from 198335? I own a 93 XJS Vin 187577. Can't readily find the DAC4841. I do have a lead on several DAC 11151. Are they interchangeable? Thanks..
Old 05-26-2015, 12:42 PM
GGG is offline
Received 16,749 Likes on 12,142 Posts
I've moved your question from General Tech Help to XJS forum. Members here with the same model will be able to help.
Old 05-27-2015, 01:24 PM
Vee's Avatar
Vee
Vee is online now
Received 1,508 Likes on 1,175 Posts
This page seems to provide some cross reference numbers.
72-10130,CARQUEST 72-10130; Sensor
MHF25 (05-28-2015)
Old 05-28-2015, 07:37 PM
MHF25's Avatar
To Vee, your link was ideal. Solved my question. Found and bought the correct sensor. Thanks so much.
PMKimpton
08-03-2019 08:22 PM
KarimPA
09-12-2015 08:15 AM
mikelibera
XJ40 ( XJ81 )
09-04-2015 05:17 PM
pocketrocket
09-03-2015 07:44 PM
innzane
09-02-2015 10:08 AM
Quick Reply: ABS wheel sensor - compatibility
