Extremely High Idle
Yes, it absolutely could be the culprit. I would recommend changing all four of your oxygen sensors at this time, however, being that they run about $80 a piece, you may want to delay that.
I would at the very least, replace the faulty oxygen sensor.
I would strongly consider changing BOTH of the the upstream sensors. The downstream ones aren't as critical. If you're willing to climb under the car and work in cramped conditions, they can usually be changed pretty easily.
NTK 25018 or Bosch 13789 is what you want. (please doublecheck me)
I have bought both over the years and have found that both are stamped NTK..including the OEM Denso products that are significantly more expensive.
Be careful with any antiseize you apply to the threads, if you are too liberal and some comes in contact with the head, you'll be replacing it. You definitely want to use some, just don't go crazy with it.
By the way, just because you've cleaned the MAF doesn't mean it isn't malfunctioning. Since you happen to have a Trouble Code, let's resolve that first though.
I go back to the other post I made suggesting that it could be your temp sensor. One way to check this out is when you have the high idle situation, you can short the sensor which would trick the car into thinking that the coolant is at operating temperature.
What you're describing is that you cold start the car, and it idles fine. I'm assuming you can drive the car and everything is fine until you shut it off and then do a hot restart? Am I properly describing the issue?
If that's the case, the coolant sensor may be sticking cold, or something, that would tell the car to increase the idle to get the car warmed up.
https://www.jaguarforums.com/forum/x.../#&gid=1&pid=1
You want to pull the plug out of #17 on the engine key above and run a wire from one plug socket to the other. (The coolant sensor itself can run unplugged, don't worry about it, youre shorting the plug that attaches on to this sensor, not the male leads on the sensor itself.)
It's worth a shot.
It's worth a shot.
#28
#30
#31
#33
And again, just to clarify, the idle is fine when the engine is cold.
What happens after startup, the car relies on a preprogrammed set of values to run the engine, until the oxygen sensors warm up, thenn it relies on actual data from three devices to idle:
1. Oxygen sensors
2. Coolant Temperature Sensor
3. MAF
You've swapped out the oxygen sensors.
You've replaced the Coolant Temp Sensor. (Part LHE1600AA, not DAC11079)
The remaining issue is either a bad MAF, which could throw a code, vacuum leak, faulty ECU, or ultimately a base idle reset.
At this point, I believe the base idle reset is your best bet.
1. Oxygen sensors
3. MAF
