Fog light round plug
Old 12-03-2016, 05:15 PM
Lotahp1's Avatar
Default Fog light round plug
Hello
I'm desperately trying to resolve the fog light issue so I can reinstall dash and see if I got that fixed. I have found a round plug that has power when the fog lights are turned on from the light switch...it is just loose and not plugged into anything. It seems that that plug is from the relay or switch and now I need to find where the matching plug from the fog lights is. I have tried to chase it under dash but have not been able to locate it. The fog light wires are red with a yello stripe. Below is a pic of the plug I need to know where it's matching plug is.
Many thanks for all assistance!
Old 12-03-2016, 05:27 PM
Lotahp1's Avatar
Default More pics
You can see three wires that I believe are fog light wires...red wires with yellow strip...going into a odd plug or coupling.
You can see two sets of these in this photo
Any idea what this soild red wire goes to???
Old 12-03-2016, 06:16 PM
Lotahp1's Avatar
Default Red plug what it for
Does anything go to this red plug? Doesn't look like enough room for a relay to plug into it because of the structure in the way.
Old 12-03-2016, 06:40 PM
Doug's Avatar
Received 10,741 Likes on 7,097 Posts
What year is your car? There were a couple different fog lamp wiring schemes.
On my '88 XJS, as I recall, the fog lamp circuit did not use that round connector. It was bypassed. Voltage from the switch went right thru the 'normally closed' contacts of the relay, thru the fuse, and on to the fog lamps.
The purpose of the relay was to *defeat* fog lamps when the high beam were on by opening the circuit
Old 12-04-2016, 04:21 AM
Greg in France's Avatar
Received 9,076 Likes on 5,344 Posts
it is just possible that the rear fog guards have to be on before the front foglights will activate.
Greg
Old 12-04-2016, 08:34 AM
Doug's Avatar
Greg
Maybe on a non-USA spec car. The USA (or any other with the big bumpers) versions didn't have the rear fog lamps!
Greg in France (12-04-2016)
Old 12-04-2016, 08:38 AM
Doug's Avatar
Not all cars had the same electrical equipment (varying mostly by market) or circuit configurations so it's very common to find vacant sockets and connectors. I dunno what that particular socket might've been used for but the wire colors might give a clue.
Old 12-05-2016, 09:07 AM
malc4d's Avatar
Red/Yellow is for switch to front fogs. Back in the good old days most cars were wired for all available options if fitted or not. Now in these cost cutting days only fitted options are wired. Seems you must find the matching plug and loom to continue or make your own.
You need to put the year and model in your threads for better help.
