Fuel Pump Relay
Sort of.
Depends as to whether its a "Fuel Infected" engine or a "Carby model".
For the Infected:
The Brown heavy wire is 12v HOT, then the ignition switches the relay ON, and then the other 2 wires are the PUMP, and EARTH. Earth is via the ECU, and its timer feature.
For the Carby:
Same deal, except the Earth is via a reverse oil switch, I THINK, as it has been a very long time.
For the Infected:
For the Carby:
Grant Francis (08-31-2015)
