Heater/ AC controls 1996 4.0
Old 06-26-2015, 03:12 PM
RagJag's Avatar
Default Heater/ AC controls 1996 4.0
The vacuum tubes from my engine to the ac controls are cut off near the firewall. I need to know which tube comes from the engine and which comes back to the water valve. This photo shows the tubes going through the firewall boot. Thanks for any help.
Old 06-28-2015, 05:49 PM
RagJag's Avatar
Surely one of you can answer this question. It would be a big help to me. I know it would be a bit of trouble to raise your bonnet and look but I do things like this quite often to help a fellow XJS owner.
RagJag
Old 06-29-2015, 11:25 AM
ptjs1's Avatar
Received 2,935 Likes on 1,956 Posts
Ragjag,
I don't know if this will help you as I have a RHD car and your US cars may have different setups anyway, but here goes:
On my car with that bulkhead boot on the left side, the pipes are as follows:
- Looking at the boot from the front of the car, the pipe that is to the left is slightly thinner and goes to the vacuum valve connected to the pipe at the back of the cylinder head.
- a slightly thicker pipe in the right of the boot (looking from the front of the car) goes to a small connector valve above and to the left of the boot on the bulkhead, and then goes to a small boss on the inlet manifold.
As I said, don't know if that helps you at all?
Paul
RagJag (06-29-2015)
Old 06-29-2015, 06:25 PM
Fesiwig's Avatar
Default 96 XJS AC/Heat control vacuum lines
in your picture; left line goes to manifold, right to heater valve
Can you tell me how to access the vacuum reservoir? I believe I have a leak somewhere.
Mitch
RagJag (06-29-2015)
Old 06-29-2015, 06:44 PM
RagJag's Avatar
Fesiwi, I do not know where the reservoir is. In fact I was unaware there was one.
Sorry.
Old 06-30-2015, 03:02 AM
malc4d's Avatar
RagJag (07-01-2015)
Old 06-30-2015, 06:11 AM
jeffriescr's Avatar
Mitch
It is a black plastic cylindrical tank under the passenger knee bulster where the fuse box
Is.
RagJag (07-01-2015)
Old 07-01-2015, 12:07 PM
RagJag's Avatar
Do the AC/heater doors work off this tank?
RagJag
Ozzy_UK
45
02-19-2019 02:05 PM
Terry007
09-04-2016 02:35 PM
Ozzy_UK
General Tech Help
01-14-2016 02:52 PM
kevinl
09-18-2015 11:00 AM
SouthernGypsy
09-03-2015 10:54 AM
Quick Reply: Heater/ AC controls 1996 4.0
