How I Feel Looking at the V12....
The following 2 users liked this post by Jagboi64:
ericjansen (01-14-2017),
Some Day, Some Day (01-14-2017)
orangeblossom (01-19-2017)
The following 6 users liked this post by Some Day, Some Day:
Doug (01-14-2017),
Flint Ironstag (01-23-2017),
Jonathan-W (01-17-2017),
orangeblossom (01-14-2017),
pdupler (01-14-2017),
and 1 others liked this post.
The following 2 users liked this post by Addicted2boost:
orangeblossom (01-19-2017),
#28
The following 3 users liked this post by JTsmks:
#30
I was a kid when the XJS came out and I remember seeing the older, wealthier people in town driving them so an XJS coupe is definitely one of the cars high on my bucket list. When I do finally clear a spot in the garage, it will have to be a v12, just because. Surely its no more confusing than the vacuum-actuated systems on my C3 Corvette.
The following 3 users liked this post by pdupler:
#31
Received 10,745 Likes
Once you resign yourself to removing xx-number of things to reach the target, and working slowly and methodically, all the apprehension goes away. When working on a Jag V12, slower is faster, if you get what I mean.
A mechanic's mirror and those telescoping magnets will become your most valuable tools, though.....right up there with your 1/4" drive socket set
The following 5 users liked this post by Doug:
Grant Francis (01-15-2017),
ronbros (01-14-2017),
#32
Mechanic's mirror? Must keep an eye out for one. I assume it's sort of like a larger dentist's mirror. Not sure what telescoping magnets are, but will do a search. Magnets on the end of a selfie stick, perhaps. I have a (simple) socket set, but it's metric - however the wrenches in the Jaguar tool kit that came with the car are also labelled in metric, so I assume by 1992 most things in the car were metric sizes.
The following 2 users liked this post by Some Day, Some Day:
orangeblossom (01-15-2017)
#33
Magnet is a similar thing, just a magnet on the end instead of a mirror. Invaluable for retrieving dropped nuts, washers, etc.
The XJS is a mix of metric and inch sizes, handy to have both in your toolkit. I've recently come across some bolts inside the differential with metric strength designations and inch sized heads! No idea if the threads themselves are metric or inch, I have not measured.
#34
#35
Magnet nearly so, it is on the end of a thin telescopic stick. ideal for retrieving sockets, nuts etc etc dropped into the maw of the V12.
Your car IS a mixture of metric and imperial, no doubt about that at all. Socket sets dirt cheap these days, just make sure the thing is made of Chrome Vanadium steel. But an undercover place to work is in my view essential - even if resourceful guys like Daim somehow manage without it. When you are cold, fed up and tired, you can just shut the door on the beast until it and you feel better!
Greg
The following 3 users liked this post by Greg in France:
#36
That is the feed into the engine of the crankcase breather. This is a system that burns fumes from that part of the engine BELOW the pistons, thus keeping the environment cleaner. Those little pipes go to a place behind the B bank airbox, and that jojns the pipe coming out of the leading edge of the airbox which goes to the "pig's Snout" [(C) G Francis], which itself is the outlet from the crankcase for fumes.
Greg
Greg
Mirror guess: Correct
Greg
Greg
I just checked. My wrenches are labelled "drop-forged steel" and my socket handle at least is labelled "chrome vanadium" though the sockets themselves are not labelled with anything. I think Costco might carry non-metric sets, though they might be cheap Chinese junk. Failing that, I can always order from overseas.
#37
Hi Someday,
Removing 'The Cruise' is a piece of Cake, the Bellows are only held in place by a Couple of Bolts and the Cable that operates it is held in place by a Couple of knurled adjusters that go on the Throttle Pedestal. (like they have on 'Push Bikes' to adjust the Gear Cables)
Once you've got the Cruise undone (15 Minutes Max) then you can tie the Cable out of the way.
When you look at the 'Cruise Bracket', you will see 3 Bolts but only undo the outside 2, unless you've got some sort of 'Death Wish' as that bolt is under pressure from the Air Con Gas.
The Hardest Part to take off is the Air Con Compressor, where the brackets have been machined to the nearest thou, which means that getting the Bolts in or out is a Nightmare!
Removing the Throttle Pedestal, isn't much fun either, where you will need to have as many Thin Fingers as 'Edward Scissor Hands' so probably best avoided unless you haven't got anything to do for the rest of the day!
As for those thin Breather Pipes that are held on by Jubilee Clips, they are no problem at all, although you might need either a pair of locking pliers or some mole wrenches, to rock them about in order to slide them off.
You can get a better idea how its done by looking near the bottom of the page, on my 'Cherry Blossom' Restoration Link.
https://www.jaguarforums.com/forum/x...-122634/page8/
Some Day, Some Day (01-16-2017)
#38
If you intend to do any serious work on the car, I have found a set of gear wrench invaluable. They are like a ratchet and ring end wrench in one. If you get the ones with the pivoting head that make them able to get into all sorts of places a ratchet and socket can't.
https://images-na.ssl-images-amazon....00-main-lg.jpg
orangeblossom (01-16-2017)
#39
You only take a looooooong time the first time.
Once something is removed for access, throttle pedestal is a classic, you will look at it, and carve the crap out it, so access to the sparkers is easier next time, soooooo, time saved further down the path.
Then you become seriously adventurous, like me, and take stuff off and leave it off.
Mine is CLEAN, and access is easy.
The following 4 users liked this post by Grant Francis:
The following 2 users liked this post by JigJag:
