How I Feel Looking at the V12....
#41
The following 3 users liked this post by Daim:
#42
So that thin pipe actually carries on inside the manifolds to join up with pipes leading into the engine somewhere, and to the crankcase somewhere else? So long as they're not full of fuel or coolant or something that won't like me removing one end to get at things below like the dizzy and leads. Although the main obstacle there is the cruise control unit. .
That's the tricky part - right now I don't have an undercover place to work on her. This is a situation I hope to change soon - within the year, ideally. However, I have discovered that there should be rental garages around, charging something like $3.00 an hour, and mechanics available for say $10.00 for ten minutes if you need a hand or get stuck. That might be something to look into. Though as I generally work seven days a week, time is a luxury
I just checked. My wrenches are labelled "drop-forged steel" and my socket handle at least is labelled "chrome vanadium" though the sockets themselves are not labelled with anything. I think Costco might carry non-metric sets, though they might be cheap Chinese junk. Failing that, I can always order from overseas.
I really counsel you against any cheapo tools. A decent socket set can be had for about 40 UKP, loads on UK ebay etc. Drop forged (as far as cheap tools are concerned) is normally a comforting way of explaining the things are made from ordinary steel and they will NOT stand up to the stresses required. Plus, often the things are not drop forged at all. NEVER economise on tool quality is an excellent maxim.
Greg
The following 4 users liked this post by Greg in France:
Grant Francis (01-16-2017),
orangeblossom (01-16-2017),
ronbros (01-16-2017),
Some Day, Some Day (01-16-2017)
#43
Hi Grant
I can see the Cruise is missing, The FPR on 'A' Bank is missing, The Cross Breather Pipes have been Re-Routed round the back of the Fuel Rail and the Injector Loom has got extended Pigtails, so that it is out of the way under the Inlet Manifold.
That Engine Room looks really Ace! but have I missed anything else that is now missing?
#44
Alex,
No balance pipe
No AAV
NO over-run valves
NO engine breather rubbish
NO pollution stuff at all
No trans kickdown switch nonsense. Compact/adjustable modulator fitted, works so well.
Cruise bellows is mounted in the apeture in front of the RHF road wheel, and the cable extened (Harley Heaven to the rescue).
Most electrical relays/resistor pack/whatever I could rip out, are relocated in the aperture behind the RHF wheel.
Fuel rail lowered, and the throttle capstan lowered accordingly.
ALL the wiring comes onto the engine from the rear, and travels forward, sooooo simple.
The rest I forget at the moment.
It took 3 weeks to rehash that engine bay, and IF I ever get another XJ-S. I would do the same and more.
No balance pipe
No AAV
NO over-run valves
The following 5 users liked this post by Grant Francis:
Daim (01-16-2017),
Doug (01-16-2017),
Greg in France (01-17-2017),
xjsv12 (01-17-2017)
#45
Hi Grant
That's Amazing!
Loads of people have trouble with the AAV
So what happens when you start her and you haven't got one and what do you do to block up the hole or whatever is showing, when you take it off.
Must save a fortune on Petrol at the very least, I reckon I waste a gallon just warming her up!
That's Amazing!
#46
Space is one of the biggest limitations to a car hobby. Here in Texas, we're blessed with lots of flat prairie and land is relatively inexpensive. Still keeps some people out of the hobby entirely and limits me more than I'd like. But lots of places in the world are much more crowded. I visited a friend in Philadelphia and he was going to show me his collection. We spent the better part of a day driving around to a half dozen different locations where he had rented a garage bay here or two there, some in private detached garages. I didn't meet any of the homeowners but I think he said they were elderly, either didn't have or need their own car and offered their garage for rent to bring in extra income. May be an option to explore.
The following 2 users liked this post by pdupler:
orangeblossom (01-19-2017)
#47
I do have one option to explore - my wife's parents' place is standing empty - but it will need a fair bit of work to render usable. That's the goal for this year. Other than that, there are so few houses with garages in the first place. The majority of Japanese houses that have on-site parking use simple car ports.
The following 2 users liked this post by Some Day, Some Day:
#48
I haven't seen any quality sets for sale here - the quality stuff is all sold separately. Which is fine, but I'm just not sure what I would need so I got a general set so I can learn which tools I most often use (assuming I actually use any!) and buy proper ones of those.
#49
Removing 'The Cruise' is a piece of Cake, the Bellows are only held in place by a Couple of Bolts and the Cable that operates it is held in place by a Couple of knurled adjusters that go on the Throttle Pedestal. (like they have on 'Push Bikes' to adjust the Gear Cables)
Once you've got the Cruise undone (15 Minutes Max) then you can tie the Cable out of the way.
Your other points and hints are also noted, thanks.
#50
Thanks very much for all that detail. I'm slightly confused by one thing, however - my cruise control "cable" appears to actually be a stiff rod, with adjusters like you say. Which I found very hard to turn when it came to adjusting the length to get the cruise control working again, so I'm not sure how well they would actually come out. One can only try, I guess.
Yours should come off complete by popping the rod off at the pedestal end (spring clip) and removing a couple fasteners at the bellows end.
The following 2 users liked this post by baxtor:
#51
Hi Someday
Probably best to keep spraying that Rod with WD40 or Penetrating Oil and then keep working it a bit until it loosens off.
As for Spanners, I get all mine from the Pound Shop, I got a whole set from the Pound Shop for only errr...One Pound! well about 5 of them anyway and they haven't broken yet.
But the best ones I got were off ebay and they were made in China, which I tried to use for undoing some very tight Caliper Bolts.
Not only that but I put them on the end of a Scaffolding Pole for extra leverage.
And then I put my Trolley Jack under the Pole and was able to lift one Corner of the Car off the Ground and the Caliper Bolts still would not come undone.
But maybe the most impressive of all was that no matter what I did, I couldn't break that Spanner, even when I went and hit it with a FBH!
And I only paid the Princely Sum of £2-88p for it!
You can see a Some Photos and a bit of a write up on these on my 'Cherry Blossom' Restoration Thread about Two Thirds of the way down the Page.
You will also notice that there is a Broken Ring Spanner, sticking out of one of those Poles and that was a Propitiatory Brand, that cost quite a lot more!
Unlike those inexpensive Chinese Spanners, that seem totally indestructible, whatever I throw at them.
So the most expensive isn't always the best.
COMBINATION SPANNER METRIC 6mm - 32mm HEAVY DUTY POLISHED CHROME VANADIUM | eBay
https://www.jaguarforums.com/forum/x...-122634/page9/
The following 2 users liked this post by orangeblossom:
orangeblossom (01-17-2017)
#53
#54
Hi Grant
That's Amazing!
That's Amazing!
AAV Removal write up.pdf
The PreHE was simpler to do than the HE, different pick up points for the balance pipe vac feed.
The following 3 users liked this post by Grant Francis:
#55
Halfords Advanced 200 Piece Socket...
Open enders and ring spanners you also need in the same sizes. Imperial eg:
Draper 29546 11 Piece Imperial Comb...
metric:
Halfords Advanced Modular Tray Set...
I know that OB will have a fit at these prices, as he is a genius for finding top notch bargains, but in the great scheme of things even if you have to pay full price, 300 quid for a superb set of tools that will last you forever is, compared with garage bills (and in Europe petrol) a steal. Plus all your wife's Christmas and birthday present worries are over, as you will always need more tools once the bug bites.
Greg
The following 2 users liked this post by Greg in France:
orangeblossom (01-17-2017),
Some Day, Some Day (01-17-2017)
#56
I think, however, something like that might be better bought on a visit to the States or the UK, where it won't cost me hundreds in shipping. I can definitely get quality metric tools here, easily. I rather like the look of those bendable ratchet wrenches posted earlier, too. I'm sure I've seen something similar here, if not terribly cheap.
Incidentally, high-octane petrol (100 RON I believe) here costs about EUR 1.16 a litre (140 yen a litre). How does that compare to other places?
Got a laugh at the idea that my wife would actually buy me presents, however....
#57
#58
If you do travel to the USA, buy tools there, that would be the cheapest place.
Usually there are 2 grades, the regular tools and those with a lifetime gaurentee. If it ever breaks, you take it back and they give you a new one, no time limit. Get the lifetime tools, even if you won't easily be able to take advantage of it, as the incremental cost isn't high, but the tools are much better.
The following 2 users liked this post by Jagboi64:
#59
your fist v12 Engine picture finally explains to me...
why every time I work on my engine my hand comes back with cuts and bloody...
heater hose failed on fri the 13th... located silicone hoses in my large shoe box...
the one missing was the one I needed... I knew where it got to...
I use it to replace the by pass hose # 321 in the wife's van one morning as we had a funeral 200 miles away and it was 5 am...
recovered it from van and popped by the GM dealer and got her correct hose yesterday neither the Van or the JagUar v12 leak now...
Premium for me works out to 83.92yen / liter...
when I use the discount 54.05 / liter
I never use the discount, I use it in the wife's Van...
though we have earned so much during the Christmas season I will have to burn some discount in the Jag or loose it...
