How to Program a New FOB 1996 XJS
Old 06-03-2010, 09:15 PM
Vee's Avatar
Vee
Vee is offline
Received 1,510 Likes on 1,176 Posts
Default How to Program a New FOB 1996 XJS
I've been searching the threads here and cannot find a definitive answer. Can someone please help me?
I'm looking to add a second remote to my 1996 XJS.
Old 06-09-2010, 10:57 PM
mcrubin_bevil's Avatar
I don't know if this will work but you can try it:
https://www.jaguarforums.com/forum/showth...ight=LJA2610AA
Old 06-10-2010, 01:01 AM
Sarc's Avatar
I don't think that link will help and the security system in the later XJ8/XK8 is different.
The security system on the XJS is kind of antiquated.
Assuming yours is a factory system, this is the only procedure I know...
https://www.jaguarforums.com/forum/s...ghlight=remote Post No. 5 by me
Old 06-12-2010, 07:48 PM
Vee's Avatar
Vee
Vee is offline
Actually, the way to get a 96 in programming mode is to:
1. Turn the car on (not engine)
2. connect the yellow w/white stripe wire with the black wire (I used two twist ties to make the connection from the back of the harness plug)
3. Turn the car back off
4. quickly tap the two wires together several times (somewhere between 5-8 times)
You'll hear some wacky noises come from under the hood. Difficult to hear with the windows up, so make sure they're down.
Old 06-14-2010, 06:47 PM
Sarc,
I can't open your picture. Will you please re-post it or email it?
Old 06-22-2010, 12:45 AM
Sarc's Avatar
Old 08-22-2013, 07:58 AM
Croftcroyne's Avatar
Cool XJS celebration remote
Sorry could you clarify where the wires are to be shorted to achieve this? Is it in the security ECU? Many thanjks from a newbie owner!!
Old 08-22-2013, 08:21 AM
AllanG's Avatar
Member Spikepaga made this video to show how to do it.
https://www.jaguarforums.com/forum/x...s-video-85375/
Cheers,
Allan
Old 08-22-2013, 02:04 PM
malc4d's Avatar
On my '92 MY the easiest way is to disconnect the battery - reconnect then push the remote button every time the alarm beeps. If more that 1 remote push each remote until beep stops (5xs or 5 remotes) ie 1st beep , remote 1. second beep, remote 2....if less that 5 remotes push 1 of them at each beep. simples.
This assumes that the alarm back up battery will be of no use by now...lol
Old 08-22-2013, 10:58 PM
Lenoat702's Avatar
Where can you get extra Jaguar key fobs from?
Old 08-23-2013, 04:41 AM
malc4d's Avatar
EBAY of course . . . . . you must check that you search for the right frequency though. Undo the four screws and open remote up. (Change the battery while open) It will be on the board. I believe the US uses 318MHz. part number should be on the back
Terry007
09-24-2015 10:36 AM
Vee
09-13-2015 12:19 PM
Rick Michael
09-06-2015 06:53 PM
My Pham
09-04-2015 03:37 PM
SouthernGypsy
09-03-2015 10:54 AM
Quick Reply: How to Program a New FOB 1996 XJS
