If Jaguar were redesigning the XJS Today what suggestions would you like to make?
#101
But, in the end it doesn't matter because beauty overcomes everything...
Cheers,
orangeblossom (05-06-2016)
#103
Convertible only (top that folds deeper in body), facelift XJS design only, plastic gas tank, place a reliable, non faulty ecu in location where water cannot get into it and damage it. Ignition coils that are reasonably priced, a tps that can be adjusted without a computer, abundant aftermarket parts supply that do not become scarce and are reasonably priced. 8 cyl pushrod engine.
#104
#105
All of the things mentioned above can be found in a Mustang or Camaro.
For it to be a Jag it would, at minimum have a SOHC. DOHC would be preferred.
Mark
#106
But I still think a Jaguar Gt should still have a V12...
#107
#108
You can get the GM aluminum block/head small block LS3's create engines from Mast Performance that put out a reliable 630 HP all motor no blower/turbo Mast Motorsports High Performance Powertrain Solutions
or the same small block with a whipple supercharger at 750 HP Mast Motorsports High Performance Powertrain Solutions
If the car can fit a big block then you are looking at 700 HP all motor with no special induction Mast Motorsports High Performance Powertrain Solutions
or 1000 HP Mast Motorsports High Performance Powertrain Solutions
These engines will keep the Jaguar cost down yet provide the power to be at the top of the food chain in power, weight and reliability.
My 3.8s is running a 460 HP all motor LS1, is a daily driver and will pull 0-60 around 3.9 seconds. I have raced the Tesla and it was a dead heat from 0-120. I am thinking of the LS3 630 HP engine after I put 300,000 miles on this engine. That is the other thing with these new V8 engines they are super reliable and will run 250,000 to 350,000 even at those performance levels, try coming close to that with a V12 you will be spending a crazy amount of money and it will not be reliable.
#110
If you are looking at fantasy Jaguar it would be better with an American aluminum block V8 as even the mighty F-type Project 7 is only putting down 567 HP and doing a 0-60 about the same 3.9 seconds as my car. A dream Jaguar should have much more power yet still be reliable.
#111
Well, all that Aston V12 talk and American V8 talk sounds interesting, but I I think I'd stick to my original idea of, yes, going wild, but still staying Jaguar, in which case it would have to be an engine like the F-Type SVR with its 575 ponies. True that OB's original plan did not limit the "dream" to necessarily a Jag power plant, but to stay "XJS" it must also stay "Jaguar", I think, otherwise it's not a Jag...
Cheers,
Cheers,
#112
#113
#114
Received 10,757 Likes
#115
this has gotten a little.... what ever...
I went and looked at a used Aston Martin DB9
and it comes stock with a V12 that FORD decided to let Aston have and not JagUar...
the 2016 has 540 out of 6.0 V12
MPG: 13 city / 19 highway (same as the XJS)
so I will just fore go all the what if's and pic up a nice used one (DB9 Convertible)
and if I get fussy retro I can take it to a customizer ( like Chip Fooze ) and have at a retro XJS body modification....
least amount of trouble for the car JagUar SHOULD be making....
though I would think these days they would have gone with a base model 4.5 liter V12 with 400 hp one as the base model....
and that V12 is based on the DURATECH.... (just two of them)
the 2009 only has 470 hp... that is the one I looked at here used...
#116
Iirc the Aston V12 has some basic Jaguar XJ13 attributes (the testbed car for a quadcam V12 from Shaguar). I'd love some quad cams... That would give the V12 the power it should be making. There are people who have managed to fit AJ16 heads... Don't ask me how, as the would be two different lengths in order to work the V12 properly...
#117
#118
The new Jaguar engines are decent but I do not think an ultimate Jag would be impressive if it does not have horsepower of at least 625HP and ideally more like 700-1000 HP. The only reliable engines of that performance at a reasonable price is the LS and American V8's. If Jag can make an engine over 700 HP that is reliable enough to run over 250,000 miles great but I have yet to see anything even close to that...
#120
Is it that Jag can't, or is that it that so far nobody really has?
Engineering is usually about tradeoffs -- 250K miles of reliable service vs. 700-1000HP is likely to be one of those tradeoffs.
I wonder what the highest mileage Bugatti Veyron is in existence?
