Marelli/Lucas Starter Overhaul
Old 08-27-2016, 09:58 AM
Daim's Avatar
Received 2,180 Likes on 1,583 Posts
Default Marelli/Lucas Starter Overhaul
Hi all,
Whilst my Marelli/Lucas (Marelli Motor, Lucas solenoid) starter is out, I was thinking of somehow overhauling it. I mean, when is it the best time to do so?
Is it possible? Before removal, it worked well and always engaged. I was thinking of taking it to pieces and at least giving it some fresh grease...
Ideas? Tips?
Damien
Old 08-27-2016, 04:48 PM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
My car ate 2 starter motors, since I fitted a reduction gear starter 8 years ago no more problems.
If I were you I would lash out on a new starter motor while you have the engine out. This starter is also about 1/2 the weight of the original.
This is similar to what I have
Jaguar E Type V12 High Torque Starter Motor JLM9712 | eBay
Old 08-27-2016, 05:46 PM
Daim's Avatar
I'd prefer to keep with the old style due to reasons hard to understand for non-Germany-residents...
My starrer works with no issue just Whilst it is out ...
Old 08-27-2016, 06:24 PM
superchargedtr6's Avatar
My Marelli starter was inspected when I had it off for replacement of the exhaust manifold gaskets. He may have been wrong, but the guy I have trusted for years showed me the brushes (4), and how two of them were completely shot. He searched for parts, and couldn't find them. I relented, and also went to the gear reduction starter. It isn't as easy as a direct replacement, yet seems very serviceable for many years to come. I don't know the laws, or the reason to only want a direct original replacement, yet wish you well in finding it.
Old 08-28-2016, 12:35 AM
warrjon's Avatar
Interesting because the reduction gear starter I used bolted to my 89 with no mods
Damien, check the brushes and bearings, if they are good then put it back in.
Uncle Fishbits
10-31-2019 11:08 AM
04-24-2019 10:51 AM
Greg in France
05-17-2016 12:12 AM
Rhett
04-06-2016 08:03 AM
Soccer6planer
10-07-2007 08:35 PM
Quick Reply: Marelli/Lucas Starter Overhaul
