Power Steering Return Line Question
Hi,
I'm looking to find out what the thread size is for the low pressure return line on my 1988 XJS. This is the fitting (male threads) that screws into the rack and pinion unit. I want to build a new hose, so am just looking for the fitting size so I can locate one. Thanks in Advance!
Received 10,749 Likes
I don't know the thread size, sorry.
If it's any help, though, I recall from my '88 XJS days just cutting off the crimp collar an installing a new hose on the existing fitting with a clamp. Worked fine. Wouldn't want to do this on the pressure hose, of course.
I use Oetiker clamps for this type of repair but a regular hose clamp would work, I reckon
Received 2,399 Likes
davidboger (12-07-2016)
That $9.69 hose is probably a length of 5/8" (I think that was the size) hose for the non-pressurized return line.
The hoses with the fittings Are quite a bit more. Do a local Google search on shops that will custom fabricate lines for you. If you ring in the needed hose, they can make an exact replica in no time.
THanks.
