Throttle Position Sensor
It is adjustable.worth removing and cleaning the plate and body. repeating butterfly and gapping. we used PDU back in the day but all that did was set throttle voltage. you would need to find voltage at idle, I can't help you with figures I'm afraid. idle valve might need resetting as well.
It is adjustable. You will have to remove it and enlargen the holes into slots. Reinstall without tightening all the way (but tighten it enough that it doesn't move).
Then, with a multimeter attached, you can adjust it to get to the proper voltage reading, 0.6v, if I recall...
