Sponsored by: DashLynx
Stock Xk muffler flap?
Old 11-06-2012, 12:40 PM
hawaii's Avatar
Default Stock Xk muffler flap?
On a stock XK muffler is there a external flap you can mechanically keep it open or is it buried in the muffler it self?
I understand the XKs flap is pure mechanical that opens on exhaust pressure right?
Thanks!
Old 11-06-2012, 02:28 PM
axr6's Avatar
Thanks!
It is a spring loaded valve unit that is external but, tack-welded to the sides of the large muffler. You can readily see it when you look under the car. You are correct, it is exhaust pressure operated.
Albert
Old 11-06-2012, 03:10 PM
SPiDi's Avatar
correct me if i am wrong, but this is only on the "R", no?
Old 11-06-2012, 04:47 PM
hawaii's Avatar
I believe the XKR is electrically operated valves and call be left open by pulling a fuse.
Is there a way to keep the "XK"s flap open all the time?
Old 11-07-2012, 10:24 AM
axr6's Avatar
No, not that I know. If you want to experiment, you could grind off the spot welds from the spring units and see if they pull out of the muffler. Then, you would have to put something in its place.
Albert
Old 11-07-2012, 05:12 PM
tarhealcracker's Avatar
In the last month or so I have run across a few 07/09 XKR exhaust mufflers for sale. This seems like an easy way to get the Quad XJR look and perhaps a performance boost.
The problem is that the XJR mufflers have an electronically activated bypass while the XKs are back pressure activated. So you end up with a muffler system on your XK with no bypass capability at all. I presume the Xks do not have the necessary circuits installed
Do you guys read it the same way?
Old 11-07-2012, 11:36 PM
axr6's Avatar
The XKs likely do not have the wiring and circuitry to operate the XKR muffler valves. However, you've just provided an idea for people interested in a bypass muffler; get the XKR muffler and simply install a dash operated switch to open and close the electric valves. Should actually be a very simple installation.
Albert
Old 11-08-2012, 01:12 AM
hawaii's Avatar
Yes great idea! What have you been seeing these used ones going for?
And where have you seen them forsale?
plums's Avatar
Received 2,166 Likes on 1,610 Posts
Go look for a adjustable barometric switch on ebay, tee into a vacuum source as a sensor then use the switch to control a relay to kick in a low vacuum. All in cost should be $30 or so.
If you want to go cheaper, you can do it with a pop bottle, some hose, a stick, some wire, thumbtacks, a relay and some water. But, it gets a mite messy.
Old 11-08-2012, 06:44 AM
There is at least 1 on the "for Sale BY Owner' forum. Also there were a few 07 and up XKs being parted out there too - as well as EBay.
Old 11-08-2012, 11:35 AM
hawaii's Avatar
Saw this on eBay ...kinda interesting and could work if it dumped out to a muffler tip next to the stock one now giving you quad tips...
http://www.ebay.com/itm/JAGUAR-XK8-2...sories&vxp=mtr
Old 11-08-2012, 12:46 PM
Default !
Jaguar XK8 2 5" Electric Exhaust Cutout System Exhaust Dump | eBay
I put some on my XJR, WOW! https://www.jaguarforums.com/forum/x...ll-pics-72079/
Vector
Larry-Cleveland
02-09-2019 03:17 PM
wichita
E type ( XK-E )
04-16-2016 04:00 AM
Johncy2000
10-02-2015 01:05 AM
baskervillema
10-01-2015 06:43 PM
Lawrence
XJ40 ( XJ81 )
10-01-2015 08:36 AM
Quick Reply: Stock Xk muffler flap?
