Hood/Bonnet lining
Old 10-18-2013, 08:04 PM
8bit's Avatar
Default Hood/Bonnet lining
Anyone know what the under-hood lining on an X150 XKR is for? If I remove it will I hear the engine/supercharger any more? Any ill-effects, like heat damage on the underside of the bonnet/hood?
Thanks in advance
Old 10-31-2013, 06:44 PM
8bit's Avatar
BUMP - anybody?
Old 10-31-2013, 06:54 PM
GGG is offline
Received 16,749 Likes on 12,142 Posts
Sound deadening and to prevent localised heat damage to the paint on the bonnet.
Old 10-31-2013, 07:32 PM
Received 9,005 Likes on 4,113 Posts
+1 on Grahams comments.............why are you thinking of removing it?
If its worn / tatty / dirty we have a member here who makes some stunning replacements.
Check out Gonzo's hoodliners at hoodliners.net I think it is
Old 11-01-2013, 08:29 AM
8bit's Avatar
I've seen some videos shot from inside the car of similar cars to mine and you can hear the supercharger - I can't really on mine, only very faintly when at very high RPM. I sort of wondered if that was because the bonnet lining was removed.
I've removed the bonnet lining on other cars in the past to hear a little more engine/turbo noise but if it's needed to prevent heat damage to the paintwork then I'd leave it be. That was all really
Old 11-01-2013, 09:53 AM
R_Rated's Avatar
If you remove the hoodliner you will definitely hear the engine and supercharger more. With the vents it is going to be next to impossible to damage the paint from heat. If anything the hoodliner holds more heat in and if you're really worried about that then get some aluminium duct tape and line it to reflect the heat. It will be more effective for heat than the hood liner - lighter - and let you hear the noises you're looking for.
richard bowles
06-10-2023 12:24 AM
Dave1109971
12-15-2015 06:16 PM
Johncy2000
10-02-2015 01:05 AM
sandmann62
10-01-2015 09:31 AM
Quick Reply: Hood/Bonnet lining
