XKR-S GT Dyno and Mods
Old 04-22-2014, 12:06 PM
russduka's Avatar
Default XKR-S GT Dyno and Mods
Just wanted to post the pre mod dyno of the GT that we had on dyno this morning. I will be posting an after modification dyno also with some video. Video is kind of hard as the car was so loud that the sound was cutting in and out on camera. Just to let everyone know I am doing a viezu tune and pulley from mike @eurotoys and also milltek high flow cats.
File Type: pdf
The following 3 users liked this post by russduka:
DGL (04-22-2014), MaximA (04-22-2014), Ngarara (04-22-2014)
Old 04-22-2014, 12:15 PM
MaximA's Avatar
I'm interested to see what your results are especially since you have high flow cats.
Old 04-22-2014, 12:19 PM
MaximA's Avatar
That is around 50HP more stock then my XKR which is inline with stock figures.
I'm betting 550-560 at the wheels with the cats, pulley and tune.
Old 04-22-2014, 12:42 PM
avos's Avatar
Received 1,062 Likes on 759 Posts
The power shown is uncorrected, so assuming it was about 11 degrees C and 1007 Mbar, it would be about 482 SAE NET rwhp, still a very good base line!
Last edited by avos; 04-22-2014 at 01:11 PM. Reason: should state uncorrected instead uncorrect
Old 04-22-2014, 12:55 PM
MaximA's Avatar
Avos-out of curiosity and future reference how did you arrive at that number? We see so many Dyno charts and it would be nice to be able to come to a correct HP. Some have been pretty close, while others have been way off.
Thank you!
Old 04-22-2014, 12:56 PM
Schwabe's Avatar
good luck with the tune
Old 04-22-2014, 01:10 PM
avos's Avatar
Thank you!
There are so many different dyno's it’s hard to compare them side by side, and assuming all environmental data is correct, and no operator errors, there can still be differences if the units haven't been calibrated (lately or correctly). Also there are 2 different SAE corrections, NET and STD (old one, and should not be used anymore), STD will under certain environmental conditions correct way higher then NET.
So best is to do a check on the same dyno, similar conditions, and use the SAE NET correction, then at least you can see the improvement. Russduka can always ask for a corrected print, it’s just a calculation, but that can be done with the after results so you have both on the same paper.
DGL (04-22-2014)
Old 04-22-2014, 01:19 PM
MaximA's Avatar
Ahh the correction, I didn't even notice it as all the Dynos I've seen lately have been "uncorrected"
Old 04-22-2014, 06:05 PM
DGL's Avatar
DGL
DGL is offline
Max, Can you give us your corrected numbers. It will be nice to have comparable numbers.
Old 04-22-2014, 06:09 PM
Lothar52's Avatar
I want to know what the diff is on the XKRS GT exhaust compared to standard XKRS?!?
Old 04-22-2014, 06:40 PM
russduka's Avatar
The only difference is the rear box. There was supposed to be more of a difference but the cars that came over to north america didn't receive same exhaust as uk spec cars due to xkrs exhaust already being at legal noise regulation limit for cars in states We have high flow cats in place and pulley on. They will finish car off tomorrow morning and then mike from eurotoys will remap car. I will also remove fuse so exhaust valves are always open
Old 04-22-2014, 06:56 PM
russduka's Avatar
Lets not assume because it was actually closer to 70 degrees Fahrenheit. The baseline of car was actually done to see what the change is in hp before and after. And also i Don't appreciate you trying to knock my numbers down either
Old 04-22-2014, 08:15 PM
ccfulton's Avatar
Received 1,106 Likes on 763 Posts
Andre isn't knocking anything, he is simply referencing the SAE standard that allows comparing dyno data across different days and conditions.
Some description of the standard and the calculation:
https://wahiduddin.net/calc/cf.htm
And a handy dandy calculator:
Dyno Correction Factor Calculator
Old 04-22-2014, 09:46 PM
DGL's Avatar
DGL
DGL is offline
482 SAE NET rwhp is very respectable. Given that the crank hp from the factory is conservatively rated at 550 you are doing good at 567 (482/85), considering a 15% delivery loss to the rear wheels through the drive train. Doing corrections so everyone has common ground for comparison is desirable not only for your individual comparison but for you to be able to compare your results against other members like Max. It will be interesting to see how your numbers compare to other members numbers. The only way to do this is to correct for any known variations. I'm sure no one is trying to disrespect your XKR-S GT numbers. I'd love to see your numbers go off the charts but they mean nothing unless we understand them.
Old 04-22-2014, 09:53 PM
JgaXkr's Avatar
How does Mike do the tune? Is he selling you a tuner for your car like we have for the Rica tune?
Old 04-22-2014, 10:26 PM
Matt in Houston's Avatar
Old 04-23-2014, 12:29 AM
avos's Avatar
I just took the temp and pressure of 8 o'clock in staten island as you said it was a run in the morning, and used the sea net calculation as an example, for a very valid question from MaximA.
Sorry for being insensitive, i'll stay out then.
Old 04-23-2014, 05:46 AM
MaximA's Avatar
Here is my Dyno which was done on a Dyno Jet.
The environmental conditions were 82.24 F 30.26 in-Hg, 16% Humidity.
Keep in mind I had a pulley on the base run but that really does noting as it just spools to the max 9 PLBS a bit quicker then is cutoff by the ECM. I actually think it hurts it in the upper range.
I also have a RSC Exhaust with a bad baffle, which is causing some added back pressure. Not sure if that made a difference or not my car just sounds like a 747 under heavy load.
I'm really interested to see the before and after Delta as that is the real difference and those cats should help quite a bit. I may be ordering a full Miltek system after these results.
Good luck with the tune I look forward to seeing the numbers!
Old 04-23-2014, 06:53 AM
DGL's Avatar
DGL
DGL is offline
Nice charts and much appreciated. Can someone, who knows what they're doing, chime in to correct the charts so we may compare them. None the less, Max's uncorrected chart shows significant gains. I hope Russduka achieves similar gains or better. After the tunes the only other test will be track performance numbers. I know Max is waiting for his ECM to come back from Eurocharged after the dealer messed it up.
Old 04-23-2014, 07:13 AM
Ngarara's Avatar
Received 1,122 Likes on 795 Posts
The other point about environment-corrected figures is that they mean you can do a more accurate before/after comparison even if the temp & pressure during the two sessions is different, which is normally the case unless you're very lucky. A baseline is only relevant if the next session is done under identical conditions, or if both are corrected.
Quick Reply: XKR-S GT Dyno and Mods
