2007 XK battery replacement
Old 10-27-2012, 12:25 PM
lspencer534's Avatar
Default 2007 XK battery replacement
I used to think I was a decent mechanic until I tried to remove the battery in my XK. I disconnected the negative cable, then the positive cable, and looked for the battery holddown. There seem to be two: one on the side of the battery, and one at the end of the battery. The one on the side of the battery is attached with 2 torx bolts. The one on the end of the battery has two nuts; the positive battery cable is secured to it.
My question: Are these the battery hold downs? O know this sounds like a stupid question, but I don't want to remove something that shouldn't be removed.
Old 10-27-2012, 01:21 PM
GGG is online now
Received 16,768 Likes on 12,155 Posts
Does this extract from the Workshop Manual help identify things?
Almost makes you think they build the car around the battery.
Attached Thumbnails 2007 XK battery replacement-battery-xk1.jpg   2007 XK battery replacement-battery-xk2.jpg   2007 XK battery replacement-battery-xk3.jpg
Old 10-31-2012, 01:01 PM
britannia's Avatar
FYI Jaguar recommends an Interstate replacement BUT it is sealed (no top up) and is made in CZ............... very disappointing . Can't believe that Interstate can ship from CZ; not mentioned on there online catalog!
No trick to remove, just heavy..........
TTFN, Adrian
Old 11-01-2012, 11:06 AM
2007 Rick's Avatar
TTFN, Adrian
What's wrong with CZ? The HLs are made there to.
Old 11-01-2012, 11:54 AM
amcdonal86's Avatar
What is CZ?
Old 11-01-2012, 11:57 AM
mosesbotbol's Avatar
Received 1,197 Likes on 931 Posts
What is CZ?
Czech Republic
Old 11-01-2012, 09:24 PM
britannia's Avatar
Plenty of batteries Made in the USA!
Adrian
Old 11-08-2012, 12:16 PM
britannia's Avatar
FYI Ford has a group 49 battery (Motorcraft BXT-49) for around $100..............haven't seen one, so no details.....but price is right! worth checking?
Adrian
JarodL
03-07-2024 01:39 AM
Charlene n John
09-28-2015 06:01 AM
Charlene n John
09-06-2015 11:03 AM
OkieTim
09-02-2015 12:48 PM
philwarner
09-02-2015 11:45 AM
Quick Reply: 2007 XK battery replacement
