XK120 XK140 XK150 1948 - 1962
Lead substitute additive?
Old 03-28-2015, 04:49 PM
sailor's Avatar
Default Lead substitute additive?
I believe my engine was overhauled in about late 70's to 80's. Has had very little engine time since then. It seems that would be about the time they went to unleaded fuel. Would it be adviseable to use a lead additive? Suggested brand?
59 XK150S
Old 03-29-2015, 12:09 PM
Jagfixer's Avatar
If it was overhauled properly it will have the hardened valve seats. Additives to some are needed but unless you are driving hard or racing all the time it is not necessary. I have driven the pre-70 Jags to 200K miles and never had a valve problem to no lead fuel. Bigger problem is pinging from too low octane. The pinging can really tear up the aluminum head.
Mikey (03-30-2015)
Old 03-30-2015, 05:48 AM
Fraser Mitchell's Avatar
Received 2,423 Likes on 1,936 Posts
It's very doubtful the valve seats will have been replaced; this is a big job, and in the 70s would have been very unusual.
As Jagfixer says, it is not usually necessary on these engines as the valve seats are normally hard enough for the kind of useage these cars get nowadays. Jaguars have been able to take unleaded since the mid-sixties,, although your cylinder head is earlier. I believe, though, all these engines had chilled cast-iron valve seats from the start. I may be wrong thogh.
However, if you're a bit nervous, try Castrol Valvemaster: -
Castrol 131396 Valvemaster Plus 250ml: Amazon.co.uk: Car & Motorbike Castrol 131396 Valvemaster Plus 250ml: Amazon.co.uk: Car & Motorbike
There are two types, the "Plus" variety also has an octane booster. I use it all the time in my MG Midget engine. The bottle has its own measurement device. It just takes slightly longer to fill up at the filling station, that's all.
sailor (04-03-2015)
Old 04-03-2015, 05:52 AM
jaguar38s's Avatar
Hello,
Addtive is never needed on the XK engines.
All heads received hardened Valve seats from Day one!!
I use Euro 95 ( unleaded fuel ) for more that 15 years on my 3.8 S-type now.
Valve clearance is still OK, after all these years ( about 25.000 Km )
Regards,
Peter Jan
sailor (04-03-2015)
Old 04-03-2015, 06:25 AM
Old Auto's Avatar
If your really keen on converting your unleaded to leaded as opposed to merely using an additive i can recommend this TetraBOOST: Product Information
Not cheap but it does what it says
sailor (04-03-2015)
Old 04-03-2015, 06:28 PM
sailor's Avatar
Default ethanol free gas?
Thanks to all for the input. Looks like it is unanimous.
Does anyone know where to purchase gas without ethanol? I think someone said you could buy it in the Seattle area. Would rather stay away from Avgas considering the cost.
Old 03-02-2016, 11:50 PM
Ethanol-free gas stations in the U.S. and Canada
Vector
Dutch xjrdiamond
11-30-2019 09:14 PM
Malihide
09-29-2015 03:21 PM
wynlaidig
09-29-2015 02:35 PM
thedugger1
09-26-2015 10:27 PM
Quick Reply: Lead substitute additive?
