Seattle XK-Car clubs
Hi All, I am now just getting back into owning a 1959 XK150S red OTS and in great shape. It has done the circuit around North America starting right here in my home town of Edmonds WA in Oct 58. Then to Vancouver BC for many years and on to Toronto where most of the recent refurb was done. The to Chicago collection and finally to me via a dealer in West Hollywood.
My question is I am looking for local Classic Jag car clubs in the North Seattle (Edmonds) area. Any help would be most appreciated.
Sailor
Sailor
Larry, I am waiting on the repair manual in the mail and my first problem is a sticky Tah that works fine for about 10 minutes or so and then stops. When I back off the knurled nut at the back of the instrument it jumps back to zero and works again for a short while. I suspect the cable needs to be cleaned and lubed. Is there a correct procedure for doing this?
Thanks for that. Will pull it and see. Looks OK and turns easily. I re-oiled it but suspect the problem is the tach itself since it works fine for maybe 10 minutes and then hangs up moving just slightly near 1000rpm with a change in rpm. A couple of other questions. The car was changed to negative ground and the choke (starting carb) connection to the sensor disconnected. I'm guessing the solenoid would not function properly with the voltage reversed and so the reason for disconnecting. I was hoping the solenoid was isolated from chassis grnd but measures a few ohms from one side and 16 ohms from the other. Others have done the positive ground conversion. I wonder if there is there any other solution so that I can get some choke function on startup?
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
