XK120 XK140 XK150 1948 - 1962
XK140 fuel tank
Old 07-25-2014, 05:36 PM
curtbrown's Avatar
Default XK140 fuel tank
Does anyone know the procedure or the easy way to remove fuel tank from a 1957 XK 140. Thanks for your help!!
Old 07-26-2014, 08:38 AM
Jagfixer's Avatar
Drain tank, unfasten all lines and wires. unbolt from frame in boot after removing liner in boot. Lift tank out. Be careful of gasoline as draining, no sparks, no smoking, keep in well ventilated area. " Not responsible for any accidents or injuries."
Old 07-26-2014, 10:42 AM
Gwuister's Avatar
When you say "lift tank out" I read that as removing the tank out through the boot (trunk).
Tank drops out through the bottom. My exhaust made it a bit harder but it snaked out OK...
Old 07-26-2014, 03:35 PM
curtbrown's Avatar
Does the boot liner unbolt from the inside if boot or does it unbolt from below. Is the boot liner hard to remove and what holds it in
Old 07-27-2014, 08:12 AM
Gwuister's Avatar
About 17 bolts and it lifts right out through the trunk.
It's the panel in front of where the spare tire sits
Old 07-27-2014, 11:26 AM
Jagfixer's Avatar
Floorboards and trunk/boot floor on 140 were of wood. I saw some restored and had steel floors welded in, not original.
JWheeler
11-22-2019 08:28 AM
dsnyder586
04-04-2019 02:38 PM
Kodiak
F-Pace (X761) / C-X17
28
07-24-2016 02:31 PM
hen555
09-07-2015 11:13 PM
deanh
09-06-2015 08:20 PM
Quick Reply: XK140 fuel tank
