Which thermostat to us/reuse?
Old 04-13-2019, 12:21 PM
Nemesis435's Avatar
Default Which thermostat to us/reuse?
I'm finishing up timing chain work on my '97 XK8 with 158000 miles and am changing out the thermostat housing and thermostat while I'm in the neighborhood. The German MotoRad thermostat that came out looks fine and I never had a problem with it. I went to AutoZone for the new thermostat and they pulled up on the options on the screen. Their Duralast piece came up with a price of $9.99, and right below it was a MotoRad option at $115.00. What ?!? Can it be that much better? I bought the Duralast, but was still wondering what made the MotoRad piece worth $115.00, and should I be putting that back in instead of the new Duralast piece?
Any experienced comments would be greatly appreciated.
Thanks,
Mark
Old 04-13-2019, 12:50 PM
DavidYau's Avatar
Received 1,417 Likes on 755 Posts
Default Failsafe thermostats
Geez, that’s big price difference.
Bear in mind that that some equipment is for racing/track/hot rods etc and then I can understand the difference.
My limited understanding is that fail safe thermostats stick wide open at a set temp., so then cannot go down again. OK for a track car but generally bad for normal cars. You may struggle to get car up to usual operating temperature, from cold, ie starting fans etc. With resulting problems such as Cabin Heater may struggle.
Thermostats are usually cheap, and easily available, so why pay the extra.
Johnken (04-14-2019)
Old 04-13-2019, 06:01 PM
car5car's Avatar
I always put thermostats in boiling water to check how far they open. Some thermostats have specs, like 1/2" opening distance. 1/4" is definitely not enough.
I spent very long time diagnosing overheating Corvette, which turned out to be bad brand new thermostat!!! I put old and new thermostats in boiling water and checked which one opened more. Old thermostat opened about 1 /2", new one about 1/4", which led to overheating.
Old 04-13-2019, 06:06 PM
avern1's Avatar
Received 1,317 Likes on 1,004 Posts
A quick google search will show the average cost of the MOTRORAD thermostat is $11.00 to $13.00. Most of the parts places like to sell them with the housing from $71.00 to $120.00.
Old 04-13-2019, 06:34 PM
bcprice36's Avatar
If your new Duralast is a 180 degree, you should be fine.....but the "Hot-Water" idea is good, just to check, as your Hot Water is probably set to 220 degrees.....never put an old one back in the car.....(advice from Grand- Dad)
Billy Clyde
giandanielxk8
02-27-2019 10:59 PM
jagxk82005seneca
01-12-2015 08:37 PM
noterman
11-30-2014 08:05 AM
ReluctantMechanic
03-31-2013 10:49 PM
dneider
12-13-2011 10:11 AM
Quick Reply: Which thermostat to us/reuse?
