97 xk8 will not start
Old 07-03-2008, 03:55 PM
test point's Avatar
Received 1,110 Likes on 932 Posts
Default RE: 97 xk8 will not start
I looked up all your codes and drew the potential conclusion that the engine overheated first. Several times the mention of low compression came up. Did the tech look at that? Do you have access to the JTIS DTC charts? They list the potential causes by each code.
Old 07-03-2008, 07:22 PM
sounds like your engine is extremly flooded.. i have had several.. cars coming from reputive jag shops.. and they can get it started.. and after 1 hr or 2 of babying the engine.. i finally get it started.. but if the walls of the cylinders have been washed down too many times.. then may need an engine..
have they check to see if the chains are intact? remove the cam covers and take a peek.
Old 07-11-2008, 07:33 PM
buyer beware from ebay
i havea friend who purchased an s type motor and got burned big time
Old 07-12-2008, 05:23 PM
hlgeorge's Avatar
Sounds like the old nikosil monster reared its head!
Old 07-14-2008, 12:06 PM
Gus's Avatar
Gus
Gus is online now
Received 2,206 Likes on 1,700 Posts
Go to my webpage and go to Nikasil and you may find the information you need. Good Luck!
JarodL
03-07-2024 01:39 AM
99xk8guy
06-05-2023 06:28 AM
99xk8guy
09-21-2019 07:34 PM
Bones
09-08-2015 08:34 PM
David Thompson
09-03-2015 07:48 PM
Quick Reply: 97 xk8 will not start
