97xk8 not starting
Old 04-05-2010, 09:51 PM
rabbits2's Avatar
Default 97xk8 not starting
I have a 97XK8 with 47,000 miles, I start it about every 2-3 weeks. Most miles are highway. When I tried to start it yesterday, it fired and then stalled, then it just turned over, and only seemed to slighlty fire but not come close to starting. I thought it could be flooded ( the dealer told me once that you could "flood start" by holding the gas pedal 1/2 way to the floor and cranking it for 30-45 seconds 2 or 3 times), but that did not seem to work. I the just let it sit overnight but again it does not start, although it seems to try.
Any ideas would be appreciated.
Old 04-05-2010, 11:51 PM
DpezXK8's Avatar
Had the same problem a while back. Make sure you battery is fully charged. Even though it may seem to crank OK try it anyways.
Old 04-06-2010, 04:59 AM
test point's Avatar
Received 1,110 Likes on 932 Posts
My view of the 'flood start' procedure is to hold the throttle fully on the floor while spinning the engine several 30-45 second sessions. Full throttle cuts off fuel preventing further flooding. Wait a minute or two between to allow the starter to cool. Then try it at half throttle.
The battery will indeed spin the engine at a voltage below what is required by the electronics causing all sorts of issues.
That doesn't work try here:
https://www.jaguarforums.com/forum/s...ad.php?t=30792
Old 04-06-2010, 07:21 AM
Gus's Avatar
Gus
Gus is offline
Received 2,207 Likes on 1,700 Posts
If your car started and then died I would be checking your fuel pressure first because that is what it sounds like to me.
Old 04-06-2010, 09:55 PM
BurgXK8's Avatar
How's your plugs? Check for carbon - or worse, oil - build up.
Old 04-06-2010, 10:05 PM
Jag69's Avatar
Default 97XK8 Not Starting
I am the last person to diagnose the problem as there are many more competent mechanics on this forum...
However...same symptoms on my car after it sat for 2 weeks. it was the fuel pump. About a $800 fix.
Old 04-06-2010, 10:07 PM
DaleD's Avatar
Location: Marin County, CA, USA - Just north of San Francisco
I had the same symptoms - Fuel pump(s) - fortunately under warranty. DaleD
JarodL
03-07-2024 01:39 AM
Dagny
07-20-2020 05:39 AM
99xk8guy
09-21-2019 07:34 PM
Bones
09-08-2015 08:34 PM
Doovoe
XJ40 ( XJ81 )
09-06-2015 10:54 AM
Quick Reply: 97xk8 not starting
