ASI Throttle Bodies - buyer beware
Old 11-13-2014, 09:18 AM
randyb's Avatar
Default ASI Throttle Bodies - buyer beware
As many of you know I had a LOT of issues with ASI, so far since September 24th when I requested my refund, I have been told 6 times my refund is being processed and as of today, no refund. Note: they received the TB back on 10/1.
I have sent eith the TB or TPS back to them 6 times (4 times I paid shipping) and never got one to work (though one did work for a week). I have been hung upped on and told I was not installing it right (3 times I had my indy mechanic try and he could not get them to work), was told once I got a different TB and it was the same one ( I know because I marked it before I sent it back) and when I told him that it was the same part, because I had marked it, he said it was rebuilt.
I have never posted about a bad experience before, but I am now because of the WORST experience I have ever had with an company.
The following 2 users liked this post by randyb:
Johnken (11-26-2014), larueb (11-14-2014)
Old 11-13-2014, 09:36 AM
RJ237's Avatar
Received 2,782 Likes on 2,226 Posts
That certainly is a different experience from what I had with my ECM repair. I will not suggest using them for throttle body repair, and hope they will post here to respond to your comment.
Old 11-13-2014, 10:38 AM
randyb's Avatar
I have read on other forums that some had good experiences, but others have posted similar experiences to mine.
Old 11-13-2014, 10:58 AM
Jon89's Avatar
Received 4,273 Likes on 2,810 Posts
Thanks for filling us in on your experience with this company. Please keep us posted. As our cars continue to age, more and more throttle bodies will need to be rebuilt/reconditioned/replaced and it is crucial for owners to know which companies do a consistently good job and which companies may create more problems than resolutions....
Good luck as you pursue your case with ASI. I hope you'll finally get a replacement throttle body that works as it should....
Old 11-19-2014, 03:16 PM
randyb's Avatar
Also, I told them I would be posting here and on other forums.
Still no refund after 7 weeks.
Old 11-19-2014, 03:21 PM
Gus's Avatar
Gus
Gus is offline
Received 2,207 Likes on 1,700 Posts
Have they explained why?
Old 11-19-2014, 09:43 PM
chopr's Avatar
Have you found a solution to your throttle body issue? Try another place? Or waiting to do that after you get your money back? Just curious...
Old 11-24-2014, 08:42 AM
randyb's Avatar
I bit the bullet and bought a new TB, wish I would have done it first. Would have saved me some money and a LOT of time.
ASI TB cost me just over $2100, new was $1450.
BTW: 7 weeks today since they got my TB and still no refund, sent them an email last Thursday and no response.
Old 11-24-2014, 09:39 AM
batroute's Avatar
I thought the TB new was about $2400? Are you willing to share the supplier at that price?
Old 11-24-2014, 11:21 AM
Gus's Avatar
Gus
Gus is offline
In reading the Refund Policy and one part says they do not refund for change of mind. If you feel strong about your position I would report it to the BBB and see what they can do for you.
Old 11-24-2014, 02:05 PM
Jon89's Avatar
You may also want to consider your state's small claims court. No attorney needed if you do your homework and handle your own case....
Old 11-24-2014, 08:39 PM
aode06's Avatar
I think you have to have our throttle bodies digitally angled at Jaguar,using their programmer, in order for a new tb/tps to work, or note your resistance before removing it.
Old 11-24-2014, 09:00 PM
Gus's Avatar
Gus
Gus is offline
Not sure about that. I never had a problem yet.
Old 11-25-2014, 03:21 AM
aode06's Avatar
Jaguar stated you must do a hard reset for a Brand New TB,and if problems persist, the TB has to be angled with the throttle blade to the ecm /calibrated digitally.My suggestion, is a member on here with the same car tell you their voltage key on engine off and you set your tps to that voltage,to help, this is why i record the voltage on every vehicle before removing the tps. or
Old 12-02-2014, 01:40 PM
randyb's Avatar
Gus,
Changing my mind would be ordering the product and then deciding I did not want the product.
This is a case of defective product and they have told me everytime I called that the refund is in process and it has been 2 months, so I am at a loos as to why you seem to be defending them.
Also, called today and asked to speak to a manager, got sent instead to the technical departments voice mail after giving the customer service rep my name. I also hired an attorney, as they are in TN and I am in AL, they seem to not want to talk to me anymore and to be honest, do not want to talk to them.
So far, I have ranted about them on 3 forums and if I do not get my refund by Friday, planning to spend the weekend bashing them. I am planning to try and run the company into the ground.
I think after 6 months and spending a ton of money, they deserve nothing less.
Old 12-02-2014, 01:48 PM
randyb's Avatar
Not yet, I got a used TB on the car now, just bought another car, so this is on the back burner. My indy told be about another company on ebay, that he has had good luck with and their name is BBA Reman.
Old 12-02-2014, 01:51 PM
randyb's Avatar
Everytime I call, they give me the same basic answer.
The refund is being processed and can take up to 30 days.
After 30 days it has been.
The refund is being processed and can take up to 30 business days and maybe slightly longer.
Old 12-02-2014, 01:59 PM
randyb's Avatar
No, all you need to do is a hard reset. You do need to take the car to jag dealer to set the TPS correctly. With ASI's procedure, you can get close but not 100%, unless you get lucky.
Old 12-02-2014, 08:30 PM
Spurlee's Avatar
Default Just to be fair...
ASI did an excellent job on my MY2000 throttle body repair in 2011. Fast and inexpensive. It went back in perfectly and fired up great.
They even owned up to an out-of-warranty repair to fix an epoxy problem that cropped up 2 years later. No charge for that.
ASI is a very small company, there's no doubt about that. I suspect that the OP's issue has gotten personal with them and, right or wrong, he'll never see a dime. (I work for a similarly small shop and know this happens.)
My experience with the handful of ABS, Top Latch and Throttle Body rebuilders, Gauge upgraders, Electrical enhancers, Pump rebuilders, Pressure Reduction Valve suppliers, S/S Hose vendors and Gauge Cluster fixers that keep our cars on the road is uniformly good. As I think back to my dealings with each, most have had the opportunity to resolve an issue and stand behind their product - ASI was one of them.
Old 12-03-2014, 03:32 PM
randyb's Avatar
I restore cars and have bought from many small companies and have never had this kind of experience before and you are wrong, I will get my money back, as I have an attorney going to court and if they still do not pay, I will use the judgement to put a lien on their business.
According to the BBB, there have been 8 complaints launched against them this year and mine makes 9.
Quick Reply: ASI Throttle Bodies - buyer beware
