Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > XK8 / XKR
Sign in using an external account
Register Forgot Password?
Search
XK8 / XKR 1996 - 2006
Sponsored by SNG Barratt
Click Here
Welcome to Jaguar Forums!
Welcome to JaguarForums.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Jaguar Forums community today!
Auto Dimming Rearview Mirror Replacement
LinkBack Thread Tools Search this Thread
Old 05-26-2009, 02:31 PM
GordoCatCar's Avatar
Send a message via Yahoo to GordoCatCar
Default Auto Dimming Rearview Mirror Replacement
My rearview mirror is losing its electro chromatic coating. It has the distinctive split in coloration: top clear and bottom coated darker. Sometimes the fluid leaves a large oval shape on the mirror. The fluid is toxic and will eat the plastic on your shifter. Not a good thing. So far none of the fluid has leaked.
This is a common problem with early model Jaguar rearview mirrors, and a known defect in the product by the manufacturer Donnelly. This particular mirror, model #011530, was originally made in Ireland by Donnelly, which went out of business (not surprised) and was bought out by Magna, a large European automotive supplier.
Note the horizontal split between the upper and lower portions of the mirror.
Click the image to open in full size.
Up to about March of 2008, the US Distributor in Holland MI, Magna Donnelly, was supplying replacements for free because of a recall. (The fluid is not toxic to humans, but it will damage your interior if it is not cleaned promptly) Replacements cost nearly $400 from Jaguar as an OEM item. So this what quite a deal indeed. The last free replacement occurred on or about October 2008. Since then, replacement mirrors are obtained through a vendor, Sybesma's Electronics, at a cost of $75.
Calling Magna Donnelly number (616-786-5115) will result in a recorded announcement saying if you are calling about a replacement interior mirror, you should contact Sybesma's Electronics. They are a contract vendor handling the mirror replacement on behalf of Magna Donnelly.
I emailed Sybesma's Electronics <orders@sybesmas.com>; and received a reply from their rep, Stacy. she sent a PDF form with instructions to return along with pics of the mirror and its mounting point. They also require info regarding the connector, its color, the number of pins and the color of the mirror wires.
The firm re-manufacturers these units, and they will ask for your old mirror as a core. This one company receives 8 - 12 auto-dimming rearview mirrors for repair EVERY DAY. The vast majority have the same problem ours do, and most are from BMWs and a few other high-end cars.
The rebuilt mirror uses a gel pack instead of the toxic fluid so at least the potential damage issue is eliminated. The cost used to be $75, but around 2010 it went up to $95.
Once they receive your old mirror data, they re-manufacturer it, and upon receipt of payment, ships it back to you. You use the shipping box to return your old mirror. Most readers report down time as short as 72 hours, but rarely more than a week. If your car is a daily driver, you can purchase a cheap stick-on mirror to use while yours is being repaired.
Overhead Console
Remove the reading light/garage door opener overhead console from the header. There are three(3) prongs holding to the header bar. Get a screwdriver in the front first. Then you can work your fingertips around to both side and pull. It pulls straight down.
This pic illustrates the three (3) rectangular slots spaced in a triangular fashion. These correspond to the prongs on the overhead console. It pulls straight down. It may not be obvious that the three (3) points are not at the edges of the cover, but rather located in about an inch from the edge.
Remove the Connector
To access the power connector you should remove the black rectangular metal bracket attached by the two torqx screws. The connector is partially hidden behind the black bracket. Below is a picture of the yellow connector showing the input side. The mirror bundle had three (3) wires: Black, White and Grey. I think the extra wires are for the rain sensing option which was not installed on my vehicle.
Remove the Mirror
The mirror on my ’97 XK8 was attached to the windshield by a parallel slide joint using a plastic detent button. Bonded onto the inner windshield is a metal clip that accepts the pedestal mount. The mirror is removed by sliding it downward off the mount.
Note the yellow paper stick-on tab marks the stamped rise which fits in the detent and locks the mirror pedestal in place on the windshield mount. The tabs on either side are what hold the mirror to its windshield mount.
A metal clip is bonded to the windshield. Note the square detent. This is the seat where the protrusion (ID'd by the yellow button) of the mirror pedestal mount snaps into place.
Push the mirror bracket down towards the dash, PARALLEL to the windshield glass. Do not pry away from the glass. Do not twist the pedestal. I used a little WD-40 to lubricate the connection.
I used a length of soft wood and light rubber hammer to GENTLY tap the base of the mirror housing and it popped off w/o incident. Other owners said they just pulled the pedestal downward and it popped off. But remember keep all motion parallel with the inner face of the windshield.
Don't bother removing the plastic covers on the mirror pedestal. They should remain attached. They use flimsy plastic tabs which you will only have glue back on after you break them off.
Some other types of mirrors use a twist on/off cam lock. Others are attached by set screws on a post. It is important to first understand how the mirror is mounted on your car. In researching this project, countless owners reported cracking their windshields because they thought it was OK to "twist it a little bit"; or they they only just "pried it up gently". So if you are not comfortable with this type of task; take your car to a windshield shop and let them show you how to properly perform the mirror removal and install.
Your Choices to Replacing the Mirror
Note: You want to insure whatever replacement mirror you get uses a chromatic gel pack or film instead of the original toxic fluid. New old stock (NOS) from the original Donnelly inventory uses fluid. Be certain of your source.
1. Jaguar Dealer (same mirror) $380-400
2. Remanufactured by Sybesma's Electronics (same mirror) $95
3. Ebay $135 + shipping. - The same Magna Donnelly mirrors (#011530) are used on a number of cars including Acuras. However, these require their connectors be cut and replaced by the Jaguar connectors.
4. **** is a supplier of similar mirrors and they sell a GENTEX mirror which is almost an equivalent (model 36100). They are available from the manufacture and retail outlets. I do not know how they fit on an XK8 and did not do research on this option. I do know that owners have had success in upgrading their mirrors using **** to add extra functions like outside temp and a compass.
4. I could find no instance of anyone successfully completing an at home fix. Some readers did drill a hole in the unit and drain the fluid; however, the mirror is no without an auto dimming function.
Additional Notes: 4/2012
Member Iconoclast added the following disclaimer by Sybesma:
“...we must open the plastics in your mirror. In the rare instance your plastics break beyond repair, Sybesma's will make every effort to find a comparable replacement but no guarantees are made.
Also, be advised that we are unable to test the operations in the home link feature, auto head lamps and rain sensor, so your mirror may or may not have this as an operable function upon completion of the repair. If unit does break, $15 will be retained as a bench fee and the remaining refunded. (If you would like your mirror shipped back, an additional shipping/handling for charges will apply)”
__________________
1993 300zx Twin Turbo; 405 HP @15 psi - 1997 XK8 Luxor Cruiser w/ 65k miles - 2001 BMW 325xit AWD Skimobile
The Following 43 Users Say Thank You to GordoCatCar For This Useful Post:
ArtyH (09-26-2013), B&DWoolley (03-18-2013), backin15 (07-21-2012), Badkitty (05-28-2011), dboydman86 (11-19-2013), Elgrosso (08-28-2014), ErnestBrant (04-14-2014), ezeddie (02-09-2012), floridabrian (11-06-2012), fstjaguar (12-07-2014), Fulton (05-23-2013), goingjag (09-02-2012), Hdpartsman00XKR (11-22-2012), jaguarcraver (11-11-2013), Jeff in Tucson (05-02-2012), jshaub (02-03-2015), lilkrissey (07-09-2012), lovemycar1 (09-26-2013), LuvMyKitty (08-03-2012), MarcisW (07-22-2014), matade (09-05-2011), MFoncerrada8 (09-26-2013), Mish_Mish (02-15-2011), mlbmark1 (05-11-2012), MrBern (04-16-2012), NikasilNik (03-29-2012), phillevo (11-02-2014), pking51 (04-13-2012), retromotors (01-11-2015), ronmexico (06-05-2011), Scotchtravelers (01-22-2014), sharay38 (08-20-2013), shayamanzi (02-23-2013), Siempa (12-26-2014), Skid Mark (08-17-2011), Stumpy (12-27-2011), teckwing (05-11-2011), The Coupe (08-02-2011), ToddL (01-22-2012), Vitamin C (05-07-2013), Wadeyzf (06-09-2013), wcnesta (09-15-2012), wheelmang (01-27-2014)
Old 05-26-2009, 04:05 PM
HogLeg's Avatar
Wow, very informative write up...hope I never need it! It's posts like this that make others' lives much easier.
Thx for the time consuming info.
Kevin
The Following User Says Thank You to HogLeg For This Useful Post:
teckwing (10-29-2011)
Old 05-27-2009, 02:03 AM
H20boy's Avatar
attaboy gordo. good post.
__________________
Matt | 2003 XK8 CvTbl | 2005 SuperV8
My Jag Galleries
Go Texas Tech!
Old 06-22-2009, 11:03 AM
this is really great information I am submitting mine now I have been looking for a replacement for this mirror. I am so glad you posted this. Thanks a million. Note. this forum has really renewed my faith in my XJ8.
Old 06-22-2009, 04:29 PM
The rebuilt unit was in very good condition. It looked brand new, and the tint change from light to dark was fast and very apparent. My old mirror was junk compared to this new one.
Total cost after shipping, etc. was about $95.
Just please be careful removing the old mirror. I am pretty certain all the early Jags used the same windshield mount as the one noted above. However, be cautious here.
Mine came off pretty easy, but in researching this tech writeup, I saw countless posts of guys who cracked their windsheild because they did not know the type of mount used and did not understand the proper procedure required to remove it. They thought they could 'wing-it' and in doing so, they busted the glass.
Otherwise this is a pretty easy, relatively inexpensive, and very satisfying project.
Gordo
__________________
The Following User Says Thank You to GordoCatCar For This Useful Post:
Old 06-23-2009, 12:11 PM
K.Westra's Avatar
keith.westra http://www.linkedin.com/pub/keith-westra/34/1bb/ba7
Any idea what model year range this affects? My 2000 XK8 just started doing this so I'm going be looking at a remanufactured one in the coming weeks. I'll let you guys know how this goes. Thanks for the thorough write up Gordo.
Old 06-23-2009, 01:58 PM
In researching this issue, I could find no cut-off dates. I think the vendor simply changed the electro-chromatic fluid to a gel, and continued to supply the industry with mirrors. If you read the history, up to about 2006-7 there was a free replacement if you turned in your old mirror. g.
__________________
Old 11-02-2009, 04:54 PM
K.Westra's Avatar
Ok, so I've been extremely slow on this, but I finally pulled my mirror and got the information to send for a replacement mirror.
One note, if your car is equipped with the rain sensing wiper option, I recommend removing the bottom plastic cover so that when the mirror is removed, the second plug can be easily removed.
Here is what the mount and plugs look like on my 2000 XK8 equipped with automatic headlights and rain sensing wipers.
This is the mount and the sensor for the rain sensing wipers:
This is the connector on the roof that the mirror plugs into:
Here is the back attachment on my mirror (which is the same mount as Gordo's) which also shows the additional plug for the rain sensor:
__________________
-Keith
2000 XK8 Convertible
The Following 3 Users Say Thank You to K.Westra For This Useful Post:
ezeddie (02-09-2012), sharay38 (08-20-2013), wcnesta (09-15-2012)
Old 11-02-2009, 05:24 PM
Does anyone know if the little plug that helps lock the mirror to the windshield mount can be had anywhere....
Dealer says not available seperately and mine is missing which gives the mirror a fair case of the shakes....
__________________
Mark
Current Stable:
2006 Black Cherry Super V8 Portfolio (for Sale!)
1985 XJ6 Vanden Plas
2001 XK8 Coupe 4.0
Old 11-02-2009, 06:21 PM
Quote:
Originally Posted by mbalce View Post
Does anyone know if the little plug that helps lock the mirror to the windshield mount can be had anywhere....Dealer says not available seperately and mine is missing which gives the mirror a fair case of the shakes...
I am not sure what part you are referring to. Are you talking about the swivel joint connecting the mounting arm to the mirror?
The mirror is held to the window by a mounting device using a slide/clip arrangement. I do not know of any 'plugs'. If the mirror was loose here, you could try to bend the metal parts in order to fit tighter as they slide together. These can be seen in the pics above.
I would be very careful bending anything attached to the window itself and if I adjusted or bent anything, it would be on the mirror assy pedestal, not the window attachment.
__________________
Old 11-02-2009, 07:30 PM
oops, I was just looking at the pics instead of reading the text closely. The little yellow sticker looked like a plastic button to me. Mine does not have any sticker but in that location is a torx head screw that holds the spring on. Not sure what the paper sticker would do if anything. I guess I will try bending the sides of the spring tighter to see if that cures the shakes. If I take the spring off the mirror I may have better ability to fit it tighter onto the windshield mount.
__________________
Mark
Current Stable:
2001 XK8 Coupe 4.0
The Following User Says Thank You to mbalce For This Useful Post:
davepsj (01-02-2012)
Old 01-28-2010, 01:42 AM
THANK YOU for this detailed post! My mirror just went (2000 XJR) and I hoped I wasn't the only one, but I couldn't have hoped for better information. Very much appreciated.
Old 09-02-2010, 02:50 PM
A big thank you
Old 09-04-2010, 08:52 AM
CRAP!!!!! cracked my windshield taking out the mirror. Oh well, another $214.67.
__________________
Scott
XK8 1999
Old 09-04-2010, 08:56 PM
Scott, do you know what went wrong? I have a '99 and need to do the replacement. Is yours the same set-up as Gordo's?
Mike
__________________
'99 XK8 Convert. Black/Tan
'05 BMW 325i
'98 Volvo XC70
'86 Albin 40 Trawler
Old 09-04-2010, 09:07 PM
Yep, I just hit the darn thing a little too hard. Just be careful or take it to a shop and they will have not problem getting it off. Lot of information on it, I just messed it up.
__________________
Scott
XK8 1999
Old 10-22-2010, 06:57 AM
Send a message via Skype™ to tesla4all
Great info...Thanks for taking your time to put this together!
Old 11-09-2010, 11:39 PM
I lost the metal clips that hold the visor flaps in place. Where can I buy them??? I am in Los Angeles.
HELP!!
Old 11-09-2010, 11:53 PM
Reverend Sam's Avatar
$214??? I priced a windshield for my car and it was $900. I have the automatic wiper sensor and the auto headlights.
__________________
2003 Jaguar XK8
That's not a decal. It's a real bird! Lucky timing.
Click RIGHT HERE to be taken to my YouTube channel. I have lots of videos which show how to repair and modify your XK8
The Following User Says Thank You to Reverend Sam For This Useful Post:
Old 11-10-2010, 12:57 AM
H20boy's Avatar
wolfy, can't get the clips separately, unless you make your own
When I superglued my clips to the visor by accident, I just bought a salvaged visor in the same color and swapped.
If you would have been 3 months sooner, you couldve had my mess and pried the clips out of it.
__________________
My Jag Galleries
Go Texas Tech!
Tags
011530, 2009, bracket, donnelly, electronics, fluid, jaguar, magna, mirror, problems, rearview, recall, removal, sybesmas, xj8, xk8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015 vBulletin Solutions, Inc. All rights reserved.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
